new to water cooling i decided to try a WC kit,i been looking at 2 1. Swiftech H20-220 Compact 3/8IN Dual 120MM CPU Liquid Cooling Kit $179.00 2. Swiftech H20-220 Apex Ultra Universal CPU Liquid Cooling Kit $229.99 on sale for $179.99 i was going to use vortex technique but mc220 w res are sold out.. if i use kit 2 wiil i need any kind of adapter to hold cpu block on.. asus M2N-E and x2 5000+ BE thank you |
No the apogee GT block comes with a retention plate. Given that the DTEK fusion V2 is on sale in the member specials plus you can price match the other components with DC you could build as similar setup with a better cpu block. 179 for the 2nd kit is a great deal though!!! |
thank you |
how does this look in comparison to the kit 2 only $189.40 1 -D-TEK Customs Fuzion V2 CPU Water Block S478/LGA775/S939/AM2/S754 1/2IN Barbs $49.99 1 -D-TEK Customs DB-1 12V Micro Silent Water Cooling Pump 1/2" G1/4 Barb Fittings $37.99 1-Swiftech MCB-120 Radbox Revision 2 Black $19.99 1 -Swiftech 7/16IN ID Vinyl Tubing 10 Feet $9.47 1-Swiftech Hydrx Water Additive Coolant 2 oz Bottle $1.99 1- Swiftech MCR220 Quiet Power Dual 120MM Water Cooling Radiator Black G1/4 Threaded $44.99 1-D-TEK Customs 1/2IN G1/4 Chrome High Flow Barb Fittings (Pair) $4.99 1-Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings $19.99 am i missing anything or have items i don't need? TIA |
The pump you chose is not as good as the MCP-655. Still it's a good pump - I have both. But the Fuzion V2 is definitely better than the Apogee GT. You're missing a second pair of metal barbs, for the micro-res (if you wish). You have only one pair for the rad. |
im only going to cool my cpu with it. or should i start with kit 2 and upgrade the cpu block later ,will the Apogee GT work as a good 1st block for newb like me? thank you |
Yes, for both questions. They are 2 very good kits. You won't be disappointed by either. |
hmm price match you say thank you |
:biggrin::biggrin: thank you |
| All times are GMT -7. The time now is 03:03 PM. |
