Old June 23, 2008, 11:33 PM
Chilly's Avatar
Originally Posted by Misoprostol View Post
Hmmm... Can't find the links anymore for the testing done at XS, but one of the users at Overclocking.net seems to think it makes a 2-3C difference. That's more than any other results I've seen, but like I said, I can't find the other results.
It could just be that I'm wrong.
Your not wrong, I am a member on XS as well, and distintly remeber those tests (he did the whole Blow Vs Suck, etc etc,) I belive there were small diffrneces BUT they were not really notable in most cases, I'll go see if I can dig it up.
Old June 24, 2008, 12:21 AM
I found an article on overclocking.net and they take the measurement of the fan hub and use that for distance otherwise generally speaking 1 38mm hub is considered a good rule of thumb.
Old June 26, 2008, 02:44 PM
elninio's Avatar
Link please
Old July 12, 2008, 03:03 PM
elninio's Avatar
http://www.martinsliquidlab.com/img/...1-38mm2000.png
ah heres what i've been looking for, discuss!
