-   Water Cooling (https://www.hardwarecanucks.com/forum/water-cooling/)
-   -   wormdrive hose clamps (https://www.hardwarecanucks.com/forum/water-cooling/8046-wormdrive-hose-clamps.html)
nikitos June 19, 2008 06:05 PM
I was wondering if you guys know of any Canadian hardware stores that carry worm drive clamps (about 5/8" diameter to be more specific). I checked canadian tire, rona and home hardware websites, but only managed to find some giant air duct clamps. I realize NCIX and others carry Primochill clamps, but those were out of stock when i ordered, and I'd rather not make another order just for the clamps. I'm in Edmonton if it matters.
Thanks!
SugarJ June 19, 2008 06:11 PM
You'll probably have to go into the stores, they don't usually put small hardware on the websites. Check the plumbing section, also maybe automotive at CDN Tire, I've seen them there before.
nikitos June 19, 2008 06:13 PM
ah that's what I thought, thanks!
Jonesy June 19, 2008 06:23 PM
If for some odd reason, like being sold out, they dont have them check an automotive store. I know Maslack here in Sudbury carrys them.
Cptn Vortex June 19, 2008 06:28 PM
Check the Auto parts section.
3.0charlie June 19, 2008 06:33 PM
Worm gear hose clamps are also used on garden hoses. That's where they primarily come from. You could also find them in the pool accessories section. It's those same clamps that are used on pool pump hoses.
Phobia June 19, 2008 11:16 PM
basically, wander all throughout canadian tire ;)
