-   -   Watercooling P5e (http://www.hardwarecanucks.com/forum/water-cooling/8032-watercooling-p5e.html)
Phobia June 18, 2008 09:18 PM
Watercooling P5e
In the near future, i want to WC my asus p5e's NB and SB. Are they the same fit as the maximus? All i see is parts for wcing maximus' chipsets, and not p5e
JD June 18, 2008 09:34 PM
I'd say so seeing as the PCB is labeled Maximus Formula, it's just covered by a sticker...
MpG June 19, 2008 12:35 AM
Check out this chart for a full compatibility listing where the EK blocks are concerned. Seems to be variation between the different X38 chipsets on the NB and SB, although the Mosfets are identical. Not sure if this is 100% accurate where other companies chipset blocks are concerned, though.
Phobia June 19, 2008 11:19 PM
awsome, thank you
Misoprostol June 20, 2008 08:30 PM
The MIPS Maximus blocks will work on the P5E
