Old June 15, 2008, 04:46 AM
Infiniti's Avatar
Default Two Loops?
Sorry for all the "Two ___" threads . Anyways, I was thinking, should I have two loops? If I do, should the north and southbridge be with the CPU loop or GPU loop?
Old June 15, 2008, 12:43 PM
Default Reply
I'd get dual loops if it fits your budget. IMHO the NB and the SB needn't to be cooled. They should only be cooled for heavy overclocking purposes. So if I were you I'd get the CPU in one loop and the GPU in the other loop.
Old June 15, 2008, 01:11 PM
Infiniti's Avatar
Ah... I see. The main reason I want to watercool my NB and SB is because I want to get rid of that noisy fan on the chipset for the 680i.. If I don't water cool them, can you recommend a good aftermarket chipset cooler for me?
Old June 15, 2008, 02:02 PM
Default Reply
NP, NCIX has plenty of NB and SB coolers around there. I recommend the one on the bottom, refer to Terrence J's review at the bottom. Since the cooler is passive it will make NO noise. BTW, if you want you can add a 80mm fan.
http://www.ncix.com/products/index.p...e=THERMALRIGHT
Old June 15, 2008, 02:57 PM
Infiniti's Avatar
Yea.. I was thinking about that one too. I'm probable going to add an AC fan.. 16Db.. If its too loud, i'll just undervolt it.
Old June 15, 2008, 03:04 PM
Infiniti's Avatar
Ohh and I've been looking at Xtreme Systems lately and I saw some pics of people's WBs and res and stuff all messed up because they did not flush out their rads, more specifically, the PA120.3. Would the same happen with a MCR220?
Old June 15, 2008, 03:14 PM
Default Reply
Yes every rad should be flushed with distilled water or hot water before putting it in a loop.
PS. I've been looking on XS too.
Old June 15, 2008, 04:29 PM
Infiniti's Avatar
AWWW... Thats soo much more work.. hehe. Hot water as in like.. boiling non distilled water right?
Old June 15, 2008, 04:57 PM
Default Reply
Ya, just non-distilled will do the trick. Well sure it's tough, but it's worth it once you get those super overclocks and lower temps.
"Life is tough and then you die." My Math teacher
Old June 15, 2008, 05:36 PM
Infiniti's Avatar
Hehe.. Good point...
