-   -   2 x MCR120 vs Dual Rad (http://www.hardwarecanucks.com/forum/water-cooling/7820-2-x-mcr120-vs-dual-rad.html)
enaberif June 5, 2008 10:02 PM
1 Attachment(s)
Ok so with my computer case layout and planning my routing and setup of rads and hoses would 2 MCR120s be more effective with high cfm fans than a single dual? Here's a layout of what I want to accomplish.
I already have the 2x120 rad but wanted to go with something a little bit different.
MpG June 5, 2008 10:26 PM
Everything I've seen suggests that rad performance within a single design tends to scale close to pretty linearly with surface area. There might be a slight edge towards multiple rads, but you're also going to increase the system's restriction, so it's probably pretty close to a wash.
That layout should work, as long as there's a supply of cool intake air for both rads to access, and you don't mind the breeze aimed forwards.
3.0charlie June 6, 2008 04:52 AM
No worries here with dual-single rads. I had those same in push-pull config that resulted in great load temps when I oc'ed that E8400 past 4.2GHz.
