Old January 13, 2018, 04:23 PM
Default Serial to parallel loop
So I want to switch to a paralell loop (only for looks) as I am aware temps will be lower and it depends on how restrictive both blocks are. My question is will it be sore on the D5 pump vs serial?
Old January 13, 2018, 04:44 PM
dustin1706's Avatar
Ignoring the usual back and fourth about serial vs parallel loops in regards to cooling, parallel will actually be less restrictive for the pump. Definitely no concern about that. The only concern (as you've already identified) is making sure that both blocks are getting flow. If the system is pretty new, good to go. If this system has been running for a long while or if you've used fluids with lots of dye, I'd clean the blocks out to make sure neither is partially plugged off.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old January 13, 2018, 08:19 PM
Mr. Friendly's Avatar
why not go with a dual pump design? just get one's that are smaller/quieter but capable?
Old January 13, 2018, 08:58 PM
KaptCrunch's Avatar
like Dustin said make Shure blocks are getting by bench testing the loop without motherboard, GPU or whatever block.
have a manifold off the pump pressure side be it 2 or more outlets , just plumb block inlets and have return going to same size cup to meter, pail to catch flow while priming
fill res and prime pump that all water block are getting flow to a pail
stop pump then fill res after all is primed
then place each cup after water block, turn on pump
turn off pump then look at cups levels
what one has the most add a flow control to that block and test again till matches cup levels on a 2 block set-up if more than 2 blocks match flow 2 and the next add another flow control to third and so on till all are even
i know its a pain but seeing is believing on parallel loop note: 2 manifolds
with serial loop its the slowest block dictates flow of loop
Old February 14, 2018, 11:36 AM
Considering doing this myself, simialr to the attached image but getting lots of mixed opinions. IMO I love how it looks and would be willing to accept a loss of a few degrees.
Old February 14, 2018, 11:41 AM
BrainEater's Avatar
It's 'Series' .
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
Old February 14, 2018, 01:43 PM
sswilson's Avatar
Originally Posted by BrainEater View Post
It's 'Series' .
Nope, the cpu is in parallel with the gpu. If it was serial there would be one line going in and out of the vid card feeding the cpu and the outlet of the cpu would be going to the res.
Your loop looks vaguely familiar.... :)
http://www.hardwarecanucks.com/forum...tml#post722505
Old February 14, 2018, 03:21 PM
SugarJ's Avatar
He was pointing out that the blocks should be referred to as being in series, not as serial loop and he was not referring to the picture. Grammar nazi stuff.
Old February 14, 2018, 10:01 PM
KaptCrunch's Avatar
yes SS but i see cpu being starved in that set-up
SJ to me it's both
Old February 14, 2018, 10:09 PM
sswilson's Avatar
Well... it worked fine for me in practice. It's really no different than having a pair of sli'd vid cards in parallel so long as there isn't a bid difference in flow between the two blocks.
SLI loop, serial or parallel stlouis1 Water Cooling 4 April 16, 2017 05:55 PM
Dual Pump in Serial vs. Parallel? Ashihtaka Water Cooling 32 July 2, 2015 04:50 PM
Switching serial loop to parallel Mnemonicman Water Cooling 9 October 26, 2012 07:44 PM
[WTB] EK Bridge Triple Serial or Parallel drkCrix Buy/Sell & Trade 0 June 16, 2012 04:33 PM
adding sli to loop - series or parallel? sukebe Water Cooling 12 January 5, 2011 11:18 PM
