-   Water Cooling (https://www.hardwarecanucks.com/forum/water-cooling/)
-   -   Cutting tubing (https://www.hardwarecanucks.com/forum/water-cooling/7678-cutting-tubing.html)
elninio June 1, 2008 09:19 AM
Cutting tubing
I'm not trolling... but I would like to know if there is a trick to getting 90 degree cuts on tubing. It always seems I'm cutting the tube perpendicular to the tube length but close inspection reveals a 30 degree cut.. Is there a simple trick to get these 90 degree cuts? I'm talking about the plastic tubing, non-metal.
enaberif June 1, 2008 09:45 AM
cut like always then get a sharp knife to trim to make it flat
Cardboard box with DSL June 1, 2008 11:51 AM
use a cigar end cutting thingy?
3.0charlie June 1, 2008 11:53 AM
That's the one I use: KwikCut SS100 Stainless Steel Tube Cutter - Black. But I have seen it in the Plumbing section of Home Depot 3 weeks ago.
Junior_1967 June 1, 2008 01:08 PM
I bought one last week at Princess Auto 8.99$
See page 253 in their online catalog, Specialty tools.
http://downloads.princessauto.com/?Lid=E
Cheers,
elninio June 1, 2008 01:14 PM
For small tubing what I use is the plier's shears, but that doesn't work for the standard size tubing. I'm using it to cut a small tube to which I am running a temp probe in, I guess a need a bigger pair of shears...
Phobia June 1, 2008 01:41 PM
hhaa i use scissors :P
biff June 10, 2008 09:07 AM
(assuming 1/2" tubing) I trim it slightly longer than needed, say 1/4", then I stick a 1/2" wooden dowel into the tube and run a sharp knife around it to trim off the excess.
CanadaRox June 10, 2008 12:57 PM
I use one of my mom's extremely sharp knives she uses for cooking (don't tell her). It's extremely sharp, and has a serrated edge like the long knife in this picture: http://www.bestdirect.tv/images/prod...yknives_34.jpg
It works great and the tubing is always cut almost 90 (rarely more than 15 off, but thats just because I get lazy).
matsta31 June 10, 2008 01:24 PM
I use the family scissors...
