Old December 3, 2017, 11:22 AM
rjbarker's Avatar
Default Noctua NT H1 Grease
Although everything on the Net doesnt state this stuff requires "break in" time....my temps have gotten very good over the past week (since orientating my Supremacy Block the right way)......I also re-applied the Noctua grease on 3930K.....and both 1080Ti's.....
I use the "X" Method with a very small dot between each leg.....
3930K @ 4.9 Ghz: 19c - 23c idle and 56c under gaming load
Both 1080Ti's 15c - 17c idle and 37c - 39c gaming (Wildlands)
Very pleased!
btw temps on both thre CPU and GPU's were almost 10c warmer with the Supremacy orientated the incorrect way.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old December 3, 2017, 11:52 AM
lowfat's Avatar
15c idle? Do you live in a dungeon or something?
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old December 3, 2017, 02:08 PM
rjbarker's Avatar
The GPU's will idle at whatever the room temp is.....this time of year that room fluctuates between 15c - 20c.....its great for benching
MARK 11: 32.530
Old December 3, 2017, 09:41 PM
I always use the dot in the middle or line method of application, as I think it reduces the chance of trapping air pockets in the TIM. If you're putting together two reasonably flat, smooth surfaces, it's hard to use too little. Also, you can only apply so much clamping force without causing problems. I think the limited clamping force and the viscosity of the TIM along with the heat cycling aiding the flow or spread is what's going on with the "break in" effect. If we all had high spec "clean rooms" to do this operation, that would also help, as a single tiny spec of lint or dust may impede the ability to transfer heat.
Old December 4, 2017, 04:06 AM
KaptCrunch's Avatar
Noctua NT H1 Grease #1 TIM
i use double cross method, 1 on each surface with staggered making an X, apply cooler and twist and pull to look if all covered and remove excess ooze then clamp
Old December 4, 2017, 09:22 AM
rjbarker's Avatar
^^^ Agree with you Kapt Crunch...Ive been using my "X" method since using EK Water Blocks. (as that was there preferred method).
I dont believe its possible to "trap" air bubbles as there far too much force applied (really....try threading down a Supremacy Water Block or securing a Water Block to a GPU PCB ).....
Jaycee had a great video whereby he demonstrated too much TIM isnt a big deal vs too little (makes total sense).
It does seem to be great grease....Couple of hours of Andromeda last night and never saw either of my GPU climb above 41c. and CPU at 52c (4.9 Ghz).
Great stuff!
MARK 11: 32.530
Old December 4, 2017, 07:35 PM
I use Moores cards and spread it out.
Mah Rig now
Mah Rig before
My stuff for sale.
Old December 4, 2017, 09:59 PM
rjbarker's Avatar
I would do the same but I KNOW I'd fvck it up and make a mess.....perhaps Bestbuy Card would be better
MARK 11: 32.530
Old December 5, 2017, 07:22 AM
sswilson's Avatar
I used to spread using the finger-wrapped-in-cellophane method, but over the last few years have just gone with the (small) pea sized dot in the middle.
edit: and no.... neither a BB nor a Moores card fits the bill IMO.... for true irony, it needs to be the CC card you maxed out buying that MB and CPU....... ;)
Old December 5, 2017, 09:21 AM
lol x2
I'll see your credit card and raise you a future shop card with extended warranty.
Mah Rig now
Mah Rig before
My stuff for sale.
Thermal pads oozing grease geoc Water Cooling 1 May 27, 2014 10:49 PM
Did I get the right Grease? Silvgearx Off Topic 8 June 8, 2012 09:02 PM
thermal compound,-tape or -grease thejanne652 Air Cooling 5 March 27, 2012 03:56 PM
CPU Grease rjbarker CPU's and Motherboards 9 September 17, 2010 03:52 PM
Thermal Grease n Lapping rjbarker CPU's and Motherboards 1 March 20, 2009 07:13 PM
