Old December 5, 2017, 08:33 PM
rjbarker's Avatar
Originally Posted by clshades View Post
lol x2
I'll see your credit card and raise you a future shop card with extended warranty.
And I'll raise you an Alaska Airlines Platinum Card.............the debt attached is free
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old December 6, 2017, 12:28 AM
To clarify a bit, in my previous post I was referring to the actual interface between the CPU's IHS or the GPU chip itself, and the heatsink. You want as much metal to metal, or metal to sand as possible. In the case of the GPU chip, you can certainly improve thermals by extending the contact patch, because any old paste is hundreds of times more thermally conductive than air. There may be some small gains by smearing paste around a CPU carrier also, but most of us don't want that mess. Ultimately the paste is there to exclude air which is a poor heat conductor. At the relatively smooth interface between CPU or GPU and the heat sink we need a tiny amount of thermal paste.
Old December 6, 2017, 03:07 AM
KaptCrunch's Avatar
yes enough paste to smear whole surface without gobbling
Old December 6, 2017, 11:42 AM
rjbarker's Avatar
It certainly isnt rocket science get that goop oin there and lets get going already Cross method...line method...pea method...its all good!
Timespy: 18.613K
MARK 11: 40.185K
Old December 6, 2017, 12:02 PM
Bartacus's Avatar
You forgot the "thin spread" method!
Old December 6, 2017, 12:54 PM
sswilson's Avatar
Originally Posted by sswilson View Post
I used to spread using the finger-wrapped-in-cellophane method, but over the last few years have just gone with the (small) pea sized dot in the middle.
edit: and no.... neither a BB nor a Moores card fits the bill IMO.... for true irony, it needs to be the CC card you maxed out buying that MB and CPU....... ;)
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC (Half Height) / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old December 6, 2017, 01:21 PM
Bartacus's Avatar
I plan to learn to read entire threads before commenting some day. It's on my bucket list.
Old December 9, 2017, 12:53 PM
The Great Gazoo's Avatar
I'll use my NCIX Advantage Rewards card so it is good for something at least.
Thermal pads oozing grease geoc Water Cooling 1 May 27, 2014 10:49 PM
Did I get the right Grease? Silvgearx Off Topic 8 June 8, 2012 09:02 PM
thermal compound,-tape or -grease thejanne652 Air Cooling 5 March 27, 2012 03:56 PM
CPU Grease rjbarker CPU's and Motherboards 9 September 17, 2010 03:52 PM
Thermal Grease n Lapping rjbarker CPU's and Motherboards 1 March 20, 2009 07:13 PM
