Old May 31, 2008, 10:01 PM
Phobia's Avatar
Default Leak in T-line
I recently bought a copper t-line from Canadian Tire, 1/2" . I built a new water cooled PC as my 2nd pc. Used old asus p5nsli, e6600 and 4 gigs of ddr2 ram. I bought a swiftech mcp655, mcr 220 qp res and apogee GT off of vortex to put in it. I started leak testing and right way it was leaking out of my t-line. i have got zapstraps on it already, as i could not get any little ring thingys *can't remember the proper name :P right now* over top of the t-line. Since it is a qp res, should i just take the t-line out and fill it from the res?
(whitty saying to be plagiarized at a later date)
Old May 31, 2008, 10:06 PM
that copper "t" will not work as there are no barbs to create a seal and water will simply bypass and leak.
Get a proper t.
Old June 1, 2008, 07:01 AM
3.0charlie's Avatar
Or use the qp res and ditch the T-line. And that "little rig thingy" is called an o-ring.
Hydro-Quebec is salivating...
Old June 1, 2008, 07:11 AM
biff's Avatar
My guess is that he's talking about worm drive clamps.
If you already have a res in the system then I agree that you should ditch the t-line.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old June 1, 2008, 07:13 AM
3.0charlie's Avatar
"zapstraps" = worm gear clamps? Geez, I taught he meant tye-wraps...
Old June 1, 2008, 07:24 AM
biff's Avatar
No I meant those "ring thingys". "zapstraps" = tie wraps is a new on on me too.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old June 1, 2008, 08:59 AM
vinister's Avatar
zapstraps a new term? cmon they been zaps for years now. ;) "zzzzzzzzzzap. snip!"
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
Old June 1, 2008, 12:47 PM
Phobia's Avatar
heh, thanks, it was the worm clamps :P see, i wouldn't mind the T-line for easy draining... :P
Old June 1, 2008, 12:55 PM
sswilson's Avatar
Heh... been "zapstraps" for quite some time in the circles I frequent. :)
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old June 1, 2008, 01:25 PM
Cptn Vortex's Avatar
Phob what tubing did you use? I only use the 7/16 stuff because it fits nice and tight. I havent tried the canadian tire T-lines and 1/2" tubing yet.....
The Vortex H20
Corsair Obsidian 500D
Asus X99-E WS
i7-5820K @4.2GHZ
RTX 2070
4x4GB Corsair LPX 2666MHZ
Thermaltake Toughpower 850W GOLD
960GB ADATA SX8200 NVME
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
EK Supreme HF, EK Vector RTX2080 FC, EK Coolstream XT 220 Rad, MCR320 Rad, EK-XTOP SPC-60 Pump, EK Multioption 100ml Res
