Old June 1, 2008, 01:40 PM
Phobia's Avatar
Thats a picture of it. and it was 1/2" tubing vortex. I had a real problem trying to get the 1/2" on it..
(whitty saying to be plagiarized at a later date)
Old June 1, 2008, 02:07 PM
there isn't enough meat on that "t" to properly seal the tube.
You would need cable ties on BOTH sides of that little bump.
Old June 1, 2008, 02:17 PM
sswilson's Avatar
At the very least, the ties would have to go on the other side of the bump. (closest to the "T").
Old June 1, 2008, 02:35 PM
Cptn Vortex's Avatar
Yeah, those look different from mine.
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old June 1, 2008, 02:43 PM
Phobia's Avatar
ya i know they do vortex :(
http://www.ncix.com/products/index.p...e=Danger%20Den
i think i'm just going to buy that, for the simplicity
Old June 1, 2008, 04:05 PM
ChuckleBrother's Avatar
I would urge you to not, its uglier and I don't know about anyone else, but I find it a hell of a job to get the tubing over plastic barbs/t-lines. Much harder to get on than over metal barbs. Like they said, just change where the ziptie is going, for moar holding.
"...you play a mean banjo"
Old June 2, 2008, 01:52 PM
lcdguy's Avatar
I personally have used danger dens 1/2 T and Y fittings. Both make excellent seals but once that tubing is on you need to cut it off :). I also use the danger den hose clamps on the plastic fittings so i don't crush them with the worm gear metal hose clamps by accident. No leaks yet going on 2 years :)
Old June 9, 2008, 04:37 PM
KaptCrunch's Avatar
this is why you has leaks for zips are in wrong loction, must be past the ridge.
for placing tubing on tee, use hot water to soften tube an push on
