Old July 29, 2017, 04:09 PM
Question (i7 4790k @ 4.0GHz) + (GTX 1060 6GB) = What Rad?
Hi guys, I need some info on a water cooling loop I wanna do.
So, i got the*'Sharkoon QB-ONE' pc case, which supports a dual 120mm*or (240mm) at the top of a maximum 5cm(50mm) height(no fans) or 2,5cm(25mm) height(with fans). Also I can add a 8cm(80mm) rad at the back of the case.
At first i wasn't planning to go water, but i think i can improve the temps, currently at*70C on max (aida64 StressTest / Forza H / The Division).
Idles temps are great at 29-39C.
I plan on getting a copper rad, cause i don't want to worry about corrosion.
BUT, if i add both the cpu and gpu on the same loop, will temps drop ? which rad tickness should i get ? Is it worth going water ?
Parts so far:
CPU Block - $:13,83*-*banggood link
GPU Bloco - $:14,99 -*banggood link
Pump - $:19,65 -*aliexpress link
90 fittings - ($:1,60 x 2) -*aliexpress link
barb fittings - ($:1,16 x 4) -*aliexpresslink
Total so far in dollars: $: 91,44 x (e-rate 3,14)
Total in my monetary unit so far: R$:287,12 (expensive)
I still have to buy the rad (R$:155,75),*the tubing (at least this i can buy locally, without getting ripped off), and an*anti-corrision concentrate.
Not sure I'll buy a reservoir, i can get away buy using a basin to fill it, then closing it under water inside glass. This will also have a quick disconnect for draining the loop. This part will be easilly acessable tru the side panel.
I don't know how to resize these pictures in forum code, so... here they are.
Old July 31, 2017, 05:47 AM
Bao Bao is offline
If you're not overclocking much, and not raising your CPU voltage. I think a single 360mm radiator is enough. or 240+120.
This is all pretty general. But I just use the template that has been kind of given to us with the CLC market. 240mm AIO's are fine for your CPU overclock, and 120mm based hybrid video cards don't drop temps as much as a full custom setup, but gets you quite close to the max boost clocks of a much more expensive water cooled setup.
And Jay's did a review with a 240mm setup which was fine enough for gaming and an OC on a similar system to yours.
I'd say it's worth a shot, but if you truly care about temps, go bigger.
Tags
gtx 1060 , help needed , i7 4790k , radiator , water cooling
Visiontek Radeon R9 280X 850MHZ 3GB 6.0GHZ GDDR5 Chris Video Cards 20 September 23, 2014 05:17 AM
E8500 On P5Q3 Deluxe over clock to 4.0Ghz drew78 Overclocking, Tweaking and Benchmarking 21 January 8, 2010 08:55 PM
[FS] (FS,FT)Mackbook 5.1 core 2 duo 2.0Ghz Overclocker~4.1 Buy/Sell & Trade 8 August 30, 2009 08:37 PM
AMD 3.0GHz Quad Unlocked.. is AMD coming back ? cwestwell Press Releases & Tech News 18 November 29, 2008 08:24 PM
CPU Temperature E8400 3.0ghz CaptainSnake CPU's and Motherboards 13 May 17, 2008 04:22 PM
