Old July 10, 2017, 09:56 AM
Bao Bao is offline
Default Where to find...
Koolance doesn't seem to have them listed anymore, but does anyone else sell something similar?
Koolance Radiator Mounting Screw & Nuts for 25mm Fans - BLT-HX025 - Screws and Nuts
Old July 10, 2017, 10:20 AM
sswilson's Avatar
I'm assuming you like the look? Is there some kind of specific functionality these provide that a straight up M4 thread hex screw wouldn't do?
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old July 10, 2017, 10:33 AM
sswilson's Avatar
https://www.dazmode.com/store/produc...ompatibility_/
Have you tried Daz? Looks like exactly the same kit....
Old July 10, 2017, 11:39 AM
Also Performance PC'S. Says they have good stock but never know until it goes into your cart.
Koolance Radiator Mounting Screw & Nut, 25mm by Koolance
Old July 10, 2017, 12:00 PM
Bao Bao is offline
Geezus, I must have missed it when I was on his site earlier.
And I wanted them because... I find it to be such a struggle bus to install fans on the "push" side of a radiator to a case (on 240 or larger rads). Stupid fans start moving and is probably the number one source of me scratching up radiators when trying to poke screws though.
This would make it easy AF!
Then I read the fine print, I don't think I have M4 compatible rads #fail.
Need help to find the right headset shilka Audio 0 January 6, 2012 06:09 AM
[WTB] FIND... Thanks Alpine Buy/Sell & Trade 8 March 23, 2011 09:55 AM
can't find it! LacrosseTown Power Supplies 9 May 16, 2010 09:40 PM
Where could I find this Meefa Audio 7 March 11, 2010 10:01 PM
Where can I find... ImmaPC Air Cooling 9 April 20, 2009 09:07 AM
