Old May 24, 2008, 11:42 PM
Dashock's Avatar
Default question aboot barbs
1. Hi all just wondering if its a good idea to use Plumbers tape on the thread of barbs when attaching to radiator or cpu block or it does not matter?
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old May 25, 2008, 12:50 AM
Cptn Vortex's Avatar
It does work, but it is a little more precise. I did it with 2 of my barbs, 1 was fine, 1 had a small small leak. about 1 drop per day...
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old May 25, 2008, 08:13 AM
lcdguy's Avatar
my personally experincec you need one the the following.
1. Barb with an O-Ring
2. Teflon Tape (might be what your calling plumbers tape)
How ever when using teflon tape it must be wrapped in the opposite direction of the thread so when it is screwed in it will get tighter and not unravel producing in a less than secure fitting.
If it were me i would go the route of metal barbs with rubber orings such as the D-tek or thermochill ones.
Old May 25, 2008, 09:46 AM
MpG's Avatar
MpG MpG is offline
You shouldn't need plumbers tape if the barb comes with an o-ring. As long as the o-ring has decent pressure against both the fitting and the block/rad/other, you shouldn't have any leakage. Myself, I use a "hand-tighten+1/3 turn with wrench" guideline for tightness, but that's admittedly pretty subjective.
Old May 25, 2008, 09:24 PM
Dashock's Avatar
yea ma barbs came with the o-ring swiftech high flow metal ones so i guess im safe then to assume im fine with just the o-ring.
Asus P5Q-E
Corsair Cx600M
Old May 25, 2008, 09:35 PM
you are fine.
Old May 25, 2008, 10:02 PM
Dashock's Avatar
thanx buddy
Asus P5Q-E
Corsair Cx600M
