-   -   Water cooling build (http://www.hardwarecanucks.com/forum/water-cooling/735-water-cooling-build.html)
SHaCK March 28, 2007 11:35 AM
Water cooling build
If anyone have an MCP-655 to sell that'd be great, they are not in stock at NCIX, expensive at bigfootcomputer and i'm tired to pay brokerage fees so won't order from the US. Other good pumps are OK too.
Thanks!
(if you know of any other place that sells them let me know)
Babrbarossa March 28, 2007 11:39 AM
I don't think there's anywhere else in Canada to get 'em. Have you asked for an eta at ncix?
Patriote March 28, 2007 11:46 AM
Swiftech MCP655 1/2in. Water Pump has some in stock. And all shipping taxes are included on your bill so no imports fees when it's delivered to your house. Ordered few times with them and good service.
Babrbarossa March 28, 2007 12:03 PM
80USD plus 42USD for shipping plus tax etc- it's going to cost you about 160 bucks canadian- (I didn't go right through the checkout procedure, so I don't know exactly)- For what it's worth NCIX's ETA on those pumps is March 30th.
Patriote March 28, 2007 12:14 PM
Wait for March 30th :thumb:
SHaCK March 28, 2007 12:46 PM
Thanks guys!
I will probably order the parts i need from NCIX finally, some parts are cheaper elsewhere some are not but paying shipping from 2 different shop isn't worth the deal.
Patriote, I know you tried various type of tubbing, what's your opinion on Vinyl tubing ? More exactly : http://www.ncix.com/products/index.p...XForumMessages
Also will 7/16"ID fit nicely on 1/2" barbs ? I think it will create a nice seal, just want to make sure.
b1lk1 March 28, 2007 03:10 PM
What parts are you looking for? I have a MCW655, a TDX, a MCW30 chipset block, a 120MM rad, a 120MM heatercore and a dual 120MM heatercore, a Danger Den fillport and a bunch of lengths of 7/16ID tubing ( that works great for 1/2" fittings) that I am thinking of selling. Everything except the rad/heatercores are new in the last few months. I'd make you a nice deal for like $150CAD + shipping for all of that stuff since I jumped to air and don't have the time to deal with watercooling. I even have a MCW60-T and a bunch of heatsinks I'd toss in for another $50 (it needs some easily found hardware I don't have). I don't really want to break it up and was hoping to sell it all as a lot. If you're interested, I will post you a pic.
Patriote March 28, 2007 03:19 PM
That tubing is actually better than Masterkleer from my own experience. But it isn't good...lol Get Tygon and nothing else if you can afford it. If not than that tubing will be Ok (Not excellent or good just Ok) Thats my opinion! And yes, 7/16" ID 5/8" OD Tubing will make a way better seal than with 1/2" ID tubing and it's quite easy to fit over 1/2" ID barbs. Only place where it could be a problem is over the barbs of the D5 ...lol If you really can't get it over the barbs just soak the end of the Tubing into hot water for a few seconds which will make the tubing more flexible and will make it slip over the D5's barbs more easily.
Actually im supposed to receive about 14 foot of Tygon 7/16" ID 5/8" OD Tubing tomorrow. Along with a new reservoir, an active NB cooler, some G11 UV blue additive and a few other things :bleh:
Gav March 28, 2007 03:36 PM
I fired off an email to NCIX and they should have stock hopefully by the end of this week if every thing goes smoothly.:biggrin:
SHaCK March 28, 2007 06:09 PM
Ah man... i've already ordered the pump from somewhere else, sorry. :doh: That's what i get for being impatient...thanks anyway man.
Might buy the lot for another rig! Will drop you a PM when the cashflow is better.
Thanks for the great info Pat, finally i've ordered 5ft of tygon 1/2"ID 3/4"OD and 10ft of Clearflex 1/2ID 7/8OD :punk:
