Old May 18, 2008, 09:19 AM
Dashock's Avatar
Default Best thermal paste for water cooling?
I was gonna buy Artic Cooling Mx-2 because everywhere i see in reviews and benchies its better then AS5 but i also see Ocz Freeze is better then MX-2 so what do yu guys use?
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old May 18, 2008, 09:54 AM
magictorch's Avatar
Default MX-2 all the way
Ive used a few different type of paste and M-2 is my favorite as it spreads so well and gives immediate results-plus its easy to clean and doesn't short anything.
Old May 18, 2008, 11:16 AM
sswilson's Avatar
Yep, MX-2 is my favorite as well. Might not top all of the benchmarks, but it's consitent and quite easy to use.
Old May 18, 2008, 02:41 PM
Dashock's Avatar
Then Mx-2 it is because i figure since im doing water cooling and i wont hit temps as high as air it wont help AS5 to cure as easily and also AS5 takes 200 hours ive used AS5 all this time not bad but i see MX-2 can drop 2 c and its no curing time so why the hell not right!
Asus P5Q-E
Corsair Cx600M
Old May 18, 2008, 03:32 PM
Default Reply
I think that a gram of Shin Etsu should do the trick.
Old May 18, 2008, 04:19 PM
Dashock's Avatar
Shin Etsu i think that stuffs avaialble in Ncix how does it compare to MX-2 or OCZ FREEZE?
Asus P5Q-E
Corsair Cx600M
Old May 18, 2008, 04:26 PM
sswilson's Avatar
Do some digging, but if memory serves correctly, it's the stuff you've got to spread like you're mudding drywall...... :)
Old May 18, 2008, 04:30 PM
sswilson's Avatar
Shin Etsu G751: Application, while difficult, is not as hard as the news on the internet makes it out to be. The use of a thin, hard, flat edge makes application easier, but still not in the same category of ease as any of the others. It does tend to blob when applied, and can be frustrating for someone with little patience. Removal was simple, though, with only a single wipe or two needed to remove the compound completely.
Techware Labs - Reviews - Thermal Paste Comparison
Old May 18, 2008, 06:00 PM
Dashock's Avatar
i think im gonna go with MX-2 even Noctua came out with some new stuff lol i been a firm AS5 for the past several years if only i knew aboot these new pastes wonder if it would have put my video card temps down too ?
Asus P5Q-E
Corsair Cx600M
Old May 18, 2008, 06:38 PM
ChuckleBrother's Avatar
I'm a big fan of MX-2 personally, its never done wrong by me
"...you play a mean banjo"
