Old February 20, 2016, 08:11 AM
r0k0's Avatar
Default Coolant life
how long is watercooling coolant life good for ?
for some reason my 4790k @ 4.7ghz is reaching 80+ degres but always ran under 50-60, i have XSPC block with a 420mm rad on push only and 280mm rad in push pull
i build this pc in 2009 using distilled water and mayham pastel with dazmode protector
Intel i7 3930K / 16GB Corsair Dominator DDR3-2400
Asus X79 Rampage Extreme Black Edition / EVGA GTX 690
Corsair Carbide Spec Alpha / EVGA NEX750 Gold
Corsair 480GB SSD / 1TB WD Black
Old February 20, 2016, 08:31 AM
Technically you are supposed to change it once a year. You should flush and clean everything out. I'm not sure that has to do with the rise of temp but it might. Is the rad dusty?
Old February 20, 2016, 08:38 AM
r0k0's Avatar
nop i clean my rads every months, its not very dusty here
this is current and the max was 2min in prime95
Old February 20, 2016, 09:27 AM
Well seeing how long has been left for I would flush it and pull the blocks off and put fresh paste on everything
Old February 20, 2016, 10:27 AM
Hooded's Avatar
Ice Dragon is good for couple years no trouble at all.
Old February 20, 2016, 10:39 AM
r0k0's Avatar
i can't remove the block, it has the indigo extreme stuff
Old February 20, 2016, 10:40 AM
r0k0's Avatar
also i just checked and Mayhem pastel are good for 2 years... so i was supposed to change it nov 2015.. couple months passed it date :P i'll go get some distilled water later and make a new batch
Old February 20, 2016, 10:55 AM
Sounds to me like the fins inside the cpu block is coated with filth and isn't transferring heat correctly. You might be able to soak it in some hot water and an o-ring safe cleaner. I've had cpu blocks do this before.
Better if you can take it apart to clean though.
Mah Rig now
Mah Rig before
My stuff for sale.
Old February 20, 2016, 11:55 AM
r0k0's Avatar
damn, i hope i have some spare paste then, i'll take my block off and clean it inside, i'll be back up in a couple of hours :P
cheers
Old February 20, 2016, 01:08 PM
lowfat's Avatar
Pastels are not good for 2 years. The particles will definitely settle before that. I personally won't ever be using them again in my rigs.
If you aren't using acrylic tubing, plasticizers are a much bigger concern than coolant though. They will clog blocks most definitely faster.
Mael
Big Lian Li
Forever Alone
coolant WolfBane Water Cooling 14 July 30, 2015 04:02 PM
Coolant Question lxxl Water Cooling 14 October 4, 2013 10:05 AM
Whered all my coolant go?? Realityshift Water Cooling 9 November 16, 2009 09:56 AM
Help With Coolant Additive Johnnyl168 Water Cooling 18 November 29, 2008 05:34 PM
What is your coolant of choice? Babrbarossa Water Cooling 26 April 14, 2007 07:22 PM
