Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
  #21 (permalink)
Old May 18, 2008, 06:42 PM
Level up: 62% Level up: 62% Level up: 62%
Level: 9 - 90 points to level up
Cool
Ughhh this is sooooo confusing. Well then in this case, I don't have much to say. BTW Varroa's thick rad is a Thermochill. Proof in link.
NCIX FORUMS - Would this rad be better than the rad in... - Thermochill Pa 120.1 Single 120MM Water ...
  #22 (permalink)
Old May 18, 2008, 06:47 PM
sswilson's Avatar
Super Moderator
Yeah, the difference is in the motherboard heatsinks. If you look at the pic, you can see that the rad is hanging quite far over the motherboard. That isn't possible with the heatsink on the DQ6.
Thanks for the link though, it verifies that a PA will actually fit given the right motherboard.
Gigabyte P35-DQ6 / E8400 / 4X 1 Gig Crucial Balistix PC2 8500 / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S /
MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / Swiftech Apogee GT WB / Samsung 931BF
DFI P965-S Dark / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 /
Creative Audigy2 / NEXUS NHP-2200 / Swiftech H20-220 / Highspeed PC Tech Station / BENQ FP91G+
  #23 (permalink)
Old May 18, 2008, 07:23 PM
MpG's Avatar
MpG MpG is online now
Level up: 60% Level up: 60% Level up: 60%
Level: 14 - 233 points to level up
Originally Posted by sswilson
I wonder if 2X PA 120.1 at opposite ends of the 3X top mount of the case would provide better cooling than the single MCR 120? That would leave the center fan mount up top as a true top exhaust.......
Originally Posted by sswilson View Post
Actually, my plan is to leave the 320 in place and supliment its cooling with a single PA 120.1.
Eh? I thought the first quote was you thinking of replacing the MCR320 with a PA120.1 at each end. (With the MCR 120 being a typo).
And I don't know how much stock I'd place in that particular Thermochill-MCR320 comparison. It's widely circulated, and the guy who did it is well-regarded, but even Thermochill's own test data doesn't quite agree with it. If you check out the thermal dissipation graphs towards the bottom of the link, you can see that the MCR-220 isn't actually that far below the PA120.2, even with 1200rpm fans.
QX9650 @ 4.0GHz (400x10) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
  #24 (permalink)
Old May 18, 2008, 07:27 PM
sswilson's Avatar
Super Moderator
Yes I was considering it, but it was only an afterthought once I found that the PA 120.1 wouldn't plug in quite the way I wanted. You suggested (and that table pretty well cemented the case) that two 120.1 wouldn't produce better results than the single 320 so I figured I'd leave that alone.
I'm pretty well convinced that I'm going to mount the single in the front with a push/pull and order myself a Fuzion V2. With that in mind, I'm going to put the single on a shelf until I get the V2 in rather than re-doing the loop twice. :)
  #25 (permalink)
Old May 21, 2008, 05:13 AM
Level up: 37% Level up: 37% Level up: 37%
Level: 9 - 149 points to level up
This is the image you're talking about right?
http://www.hardwarecanucks.com/forum/49113-post30.html
Sorry I missed this one guys but yes I can confirm this is a thermochill on the back of my case, it is cooling my CPU alone. The 2x120 uptop is cooling my NB and my 2900XT using a coolance full coverage GPU block.
Win XP SP2, E8400 @ 3.6Ghz, Asus P5K-E, HIS HD2900XT, Patriot 2 x 2 GB DDRII 800 ram (4-4-4-12), 2x500 Gig WD and 1x150 Gig Raptor HDD, 2 Optical Drives, Corsair HX620W PS, Auzentech X-Fi Prelude and Coolermaster Cosmos case all watercooled!
Win MCE 2005, FX-60 @2.6 Ghz, Asrock 939 Dual Vsta, 2x1024 OCZ Platinum DDR400 (2-3-2-5), 160gig WD IDE HD, 1 optical drive, Powercolor 512mb 3650 AGP, Creative Audigy ZS 2 Plat, ATI 550 Pro TV card, OCZ GameXtream 600watt PS in a Coolermaster case.
Forum Jump
Search this Thread:
Advanced Search
