  #21 (permalink)
Old May 18, 2008, 07:42 PM
Cool
Ughhh this is sooooo confusing. Well then in this case, I don't have much to say. BTW Varroa's thick rad is a Thermochill. Proof in link.
NCIX FORUMS - Would this rad be better than the rad in... - Thermochill Pa 120.1 Single 120MM Water ...
  #22 (permalink)
Old May 18, 2008, 07:47 PM
sswilson's Avatar
Super Moderator
Yeah, the difference is in the motherboard heatsinks. If you look at the pic, you can see that the rad is hanging quite far over the motherboard. That isn't possible with the heatsink on the DQ6.
Thanks for the link though, it verifies that a PA will actually fit given the right motherboard.
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
  #23 (permalink)
Old May 18, 2008, 08:23 PM
MpG's Avatar
MpG MpG is offline
Level up: 44% Level up: 44% Level up: 44%
Level: 15 - 365 points to level up
Originally Posted by sswilson
I wonder if 2X PA 120.1 at opposite ends of the 3X top mount of the case would provide better cooling than the single MCR 120? That would leave the center fan mount up top as a true top exhaust.......
Originally Posted by sswilson View Post
Actually, my plan is to leave the 320 in place and supliment its cooling with a single PA 120.1.
Eh? I thought the first quote was you thinking of replacing the MCR320 with a PA120.1 at each end. (With the MCR 120 being a typo).
And I don't know how much stock I'd place in that particular Thermochill-MCR320 comparison. It's widely circulated, and the guy who did it is well-regarded, but even Thermochill's own test data doesn't quite agree with it. If you check out the thermal dissipation graphs towards the bottom of the link, you can see that the MCR-220 isn't actually that far below the PA120.2, even with 1200rpm fans.
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
  #24 (permalink)
Old May 18, 2008, 08:27 PM
sswilson's Avatar
Super Moderator
Yes I was considering it, but it was only an afterthought once I found that the PA 120.1 wouldn't plug in quite the way I wanted. You suggested (and that table pretty well cemented the case) that two 120.1 wouldn't produce better results than the single 320 so I figured I'd leave that alone.
I'm pretty well convinced that I'm going to mount the single in the front with a push/pull and order myself a Fuzion V2. With that in mind, I'm going to put the single on a shelf until I get the V2 in rather than re-doing the loop twice. :)
  #25 (permalink)
Old May 21, 2008, 06:13 AM
Level: 8 - 234 points to level up
This is the image you're talking about right?
http://www.hardwarecanucks.com/forum/49113-post30.html
Sorry I missed this one guys but yes I can confirm this is a thermochill on the back of my case, it is cooling my CPU alone. The 2x120 uptop is cooling my NB and my 2900XT using a coolance full coverage GPU block.
Win XP SP2, E8400 @ 3.6Ghz, Asus P5K-E, HIS HD2900XT, Patriot 2x2GB DDRII 800 (4-4-4-12), 2x500GB WD HDD and 1x150GB Raptor HDD, BD/HD-DVD Drive, Corsair HX620W PS, Auz X-Fi Prelude, Intel Pro GT Gbit NIC & Coolermaster Cosmos case all watercooled!
Win MCE 2005 SP3, FX-60, Winfast NF4UK8AA-8EKRS, 4x1GB OCZ Plat DDR 400 (2.5-3-3-8), 160GB WD HDD, 1 DVD drive, BFG 8800GT OC 512mb PCI-E, Audigy ZS 2 Plat, 2xATI 550 Pro TV card, Intel Pro PT Gbit NIC, OCZ GameXtream 600W PS & Coolermaster case.
  #26 (permalink)
Old September 4, 2008, 09:55 PM
sswilson's Avatar
Super Moderator
Cross posting this as they were two different discussions and it might get missed if somebody is trying to get a PA120.1 to fit on the lower intake of a Cosmos S....
Coolermaster Cosmos S
It will fit, you just need to pull out a dremmel. (A drill would work as well, but I didin't trust myself not to drill all the way through... :) ).
  #27 (permalink)
Old September 11, 2008, 04:12 PM
You could always mount it on the rear exhaust:
  #28 (permalink)
Old September 11, 2008, 04:34 PM
sswilson's Avatar
Super Moderator
I looked at that, but unfortunately the chipset cooling on my DQ6 is in the way.
Did manage to get it in on the bottom though. :)
