LinkBack (1) Thread Tools Display Modes
Old May 13, 2008, 06:02 PM
CanadaRox's Avatar
Level up: 31% Level up: 31% Level up: 31%
Level: 10 - 194 points to level up
You could always get a second pump and res and split the loops. The external and 9800GX2 on one loop, and the internal for the CPU alone, and then the NB could be put on either loop really, not a huge heat dump from it.. That should keep it all nice and cool, without even the need to add another res.
But this would depend on your current temps.
X3350 @ 3.6GHz | Asus P5Q-E |2x2GB Dominator @ 1080MHz
VisionTek 4870 @ 825MHz/4.6Ghz|WD 640GB Black
PCP&C 750W Silencer | HT Omega Claro
X3350 @ 4187MHz
Old May 13, 2008, 06:06 PM
magictorch's Avatar
Level up: 96% Level up: 96% Level up: 96%
Level: 17 - 34 points to level up
Default random suggestion
How about a triple rad instead of one of the external double and tie the gpu into that?
I know your not keen on the idea of a rebuild and more money though. I guess you can just try the single and take it from there--you'll probably be pleasantly surprised anyway cw stock cooler- that GPU is hotter than a goldminers lunchbox.
E6750 + Apogee GT block
DFI X38 LT
2x4870
74gb Raptor for OS, games
Thermalrock Dragon Case (sprayed black)
Loop 1: MCR 220 int. + cpu
Loop 2: MCR 320, Swiftech Res. +
2x EK FC blocks)
Pumps: 2x MCP655.
Old May 13, 2008, 06:23 PM
Dashock's Avatar
Level up: 84% Level up: 84% Level up: 84%
Level: 16 - 120 points to level up
pats his XFX 8800 GT its times like this im glad i bought it runs cool runs well and plays BattleStar Galactica HD superbly!!!!
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old May 13, 2008, 06:30 PM
Cptn Vortex's Avatar
Level: 21 - 834 points to level up
Yeah....knowing me I will find a way to re-build....I know.... Luckily this time, I installed a T-line at the bottom of my loop, so as to drain it easily. Thinking ahead!
The Vortex H20
Case....not sure what to call it
DFI X38 LT
Xeon X3210 @ 3.2GHZ 1.30V
PNY 9800GX2 (750/2200)
4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V
Ultra X3 1000W PSU
HT Omega Striker
2x500GB Hitachi RAID 0, 250 Seagate
Sharp 32" Aquos 1080p
Benq W500 1080i Pojector.
Watercooling:
Loop 1 - D-Tek Fuzion Quad Nozzle Bowed, MCR320+Zalman ZM-F3 Fans, MCP655, MCRES Micro.
Loop 2 - DB-1, DD 9800GX2 block, MCW30, MCR320, tLine res.
Old May 13, 2008, 06:49 PM
Dashock's Avatar
A T-line maybe i should think into that eh what do yu think ?
Asus P5Q-E
Antec Spot Cool
Logitech X-230
Old May 13, 2008, 06:58 PM
It's easy enough to add one. After draining my loop about 5 times I realised it would be handy....
The Vortex H20
DFI X38 LT
Ultra X3 1000W PSU
HT Omega Striker
Watercooling:
Old May 13, 2008, 09:26 PM
sswilson's Avatar
Super Moderator
What about spending the big bucks for a Thermochill PA 120.1? They're pricy, but supposedly well worth the extra coin performance wise.
I just ordered up one to add to the Cosmos S (bottom front fan intake). I'll let you know once I get it installed if it made much of a difference added to the same loop as a MCR320 Push/Pull config.
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
Old May 13, 2008, 10:16 PM
Level up: 5% Level up: 5% Level up: 5%
Level: 10 - 266 points to level up
It looks like you might be able to replace both rads with triples, that would surely do it.
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X4 9850
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870 @ 900/1300, hard-modded
  #19 (permalink)
Old May 14, 2008, 12:21 AM
..... not about to spend the cash on replacing both my Rads with tripples....already have one PA120.2...costs a pretty penny itself. I will try with the single 120mm RAD, and if not good enough, then I will make room for a second. I will run 2 seperate loops.
The Vortex H20
DFI X38 LT
Ultra X3 1000W PSU
HT Omega Striker
Watercooling:
  #20 (permalink)
Old May 14, 2008, 03:08 PM
MpG's Avatar
MpG MpG is offline
Level up: 44% Level up: 44% Level up: 44%
Level: 15 - 365 points to level up
Is that GX2 really noiser than those Ultras at 1500rpm? Damn, that's terrible.
Swiftech states that their single rad should be able to dissipate 100W at a 10 degree temp air-water delta, using a 1200rpm/47cfm fan. Since your Ultras are quite a bit more powerful than that, so even more heat could be handled with such a fan (probably over 150W, to extrapolate from the Swiftech graphs). Now, if you use a 20 degree delta instead of 10, you can double the heat capacity. Say 200W, to be very conservative, which is about the level of your card at max load.
Now, I routinely see people reporting temps in the 50's with that card under water, so with the extra 10 degrees in air-water delta, you could reasonably expect temps in the 60's, even at max load.
Anyways, that's my 2c.
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/water-cooling/7046-9800gx2-single-120mm-rad.html
Posted By For Type Date
pic request (tj-09) rad q - XtremeSystems Forums This thread Refback July 20, 2008 04:55 AM
