Old August 7, 2015, 06:38 PM
WolfBane's Avatar
Default Split rads or not
I have 2 rads should I split them between the cpu and the vid card or run them as one system ?
1 rad holds 3 fans the other rad holds two fans ....
I USE EMT ONLY
Remember... Four boxes keep us free: the soap box, the ballot box, the jury box, and the cartridge box.
Old August 7, 2015, 08:02 PM
I always suggest running through all the rads instead of splitting them. There is no benefit to splitting them up. Cool the water as much as possible prior to the blocks.
Mah Rig now
Mah Rig before
My stuff for sale.
Old August 7, 2015, 08:05 PM
WolfBane's Avatar
so I should run the rads back to back before entering the cpu and video card?
I USE EMT ONLY
Old August 7, 2015, 08:45 PM
KaptCrunch's Avatar
after pump>rad>blocks
Old August 7, 2015, 08:53 PM
WolfBane's Avatar
thanks guys :)
now should I run both rads or just a 3 fan rad?
or just the two fan rad?
I USE EMT ONLY
Old August 7, 2015, 09:05 PM
biff's Avatar
Unless things have changed since I last looked into this, CPU's OC better when cooler... GPU's don't care so much. This is why I run two independent loops. Overkill probably.
The order of the components doesn't matter. This has long since been proven. An organized flow is much more important. Yeas ideally you would go pump to rad to block, but lay it out as best fits in your situation to maintain a nice flow.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old August 7, 2015, 09:15 PM
WolfBane's Avatar
nice :)
think I will go pump to two rads to cpu then vid card back to rez :)
I USE EMT ONLY
Old August 8, 2015, 06:04 AM
That's how I run mine.
Mah Rig now
Mah Rig before
My stuff for sale.
Old August 8, 2015, 06:23 AM
WolfBane's Avatar
I USE EMT ONLY
Old August 25, 2015, 05:43 PM
WolfBane's Avatar
ok i decided to run my system in this switch 810 case ( what a pain modding ) but my question in on the 2 fan rad that sits in the very bottom of the case .
if i have the fans blow downwards then there is a screen filter then the desk , will this be enough room to vent the heat off of the 2 fan rad?
or should i vent it into the case which would pull more cool air threw the rad? but also more hot air into the case?
I USE EMT ONLY
Anybody want to split monsoon pro bending kit? turtletrax Off Topic 13 July 10, 2015 07:59 PM
Rumor of AMD Split Up moocow Press Releases & Tech News 6 June 23, 2015 04:54 PM
Every 5 seconds, the CPU stutters for a split second Menello Troubleshooting 6 September 18, 2010 08:15 AM
Split Screen Gaming on PC way Gaming 11 December 7, 2008 04:54 AM
A.M.D. to Split Into Two Operations yamawho Press Releases & Tech News 7 October 7, 2008 11:18 AM
