calculate gpm?
wonder...
i would like to know how many 355 mpc to do the watercooling job.. one or two pump(s)?
watercooling parts
- 2x darkside radiator ( https://www.dazmode.com/store/produc...ush-pull-only/ )
- 2x koolance ar-697
- 1x EK-Supreme HF - Full Nickel - Supreme HF - CPU Blocks - Blocks - EOL
- 1x 250mm ek reservoir ( EK-Multioption RES X2 - 250 Basic - Reservoirs - Reservoirs & Accessories - EOL)
sooo how do you calculate gpm? does gallon matter? look at two monster radiators!
2x top available to choose
- 1x ek d5 dual top @ EK-DDC Dual TOP V.2 G1/4 - Black Acetal - Pumps Tops - Pumps & Accessories - EOL
- 1x ek d5 top @ EK-DDC X-TOP G3/8 - Acetal - Pumps Tops - Pumps & Accessories - EOL
3x pumps available to choose
- 2x mcp 355
- 1x mcp 35x
--- NEW: customize case, XFX 750W, i7 4770k, supreme hf, GA-Z87X-OC Force, 16gb gskill ripjaws 2133mhz , xfx hd6950 CF. 128gb intel 520, wd blue and toshiba 1tb, mcp355 + EK-XRES , 2x ar697, 2x PXM360, 12x AC F12 fans, 12 x shroud, STT 123W fan filter. 2442.88CDN OLD: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans. |
