-   -   Watercooling Reservoirs (http://www.hardwarecanucks.com/forum/water-cooling/6942-watercooling-reservoirs.html)
enaberif May 9, 2008 06:44 PM
Can you use anything you want for a resevoir as long as there is a in and out? Like say could I use a glass jar?
chibi_man May 9, 2008 07:07 PM
Absolutely.
I've used a number of Items. My favorite is ABS (Black pipe), it seals perfectly and once your force thread a brass barb into it it's leak proof. I use some glue around the barbs just for extra assurance against a leak.
Other options are plastic containers from a dollar store, but they take more rigging to make work.
Use your imagination.
Cptn Vortex May 9, 2008 07:10 PM
A Human Skull?
enaberif May 9, 2008 07:10 PM
Originally Posted by chibi_man (Post 56828)
Absolutely.
Figured as much.
Second can a resevoir be too big?
3.0charlie May 9, 2008 07:18 PM
Originally Posted by enaberif (Post 56830)
Figured as much.
Nope.
sswilson May 9, 2008 08:00 PM
Biggest resevoir I ever heard of (on-line) was an outdoor swimming pool...... :)
enaberif May 9, 2008 08:04 PM
1 Attachment(s)
heres an taste of my modded 690 case ;)
all water cooling components will be in the bottom.. maybe more.. haven't decided.
MpG May 10, 2008 06:52 PM
Nice!
Just make sure that 1) the pump is kept fed with water, 2) the exit for the reservoir is below the water line, and 3) that there's a drain in the reservoir.
chibi_man May 11, 2008 07:37 PM
I agree with MpG.
Thats a tricky thing with some reservoir models so keep that in mind.
The Ideal thing would be to have all the water cooling components on the top of the case. My first rig I ever made with water cooling had it all on the bottom, and it was a really pain getting the air out of the system and on top of that heat rises, just a tip.
What style reservoir do you have in mind? (Square, cylinder, funky shaped, etc)
ABS pipe does wonders so that be my choice.
enaberif May 11, 2008 08:07 PM
Originally Posted by chibi_man (Post 57110)
I agree with MpG.
Heat won't be an issue as it will be all insulated except for 2 panels which will allow the fans to bring air in and out of the bottom enclosure.
Reservoir is going to be round but I haven't decided on size yet.. I'm thinking like 8" or so high by maybe 3" round and will be probably clear acrylic.
