Old April 1, 2015, 08:21 AM
MuffinWRX's Avatar
Default ASUS Poseidon Watercooling
Hey all, I have an ASUS Poseidon 780, and am wondering if I were to switch to water cooling, what would I need to accomplish it? What do you reccomend?
Thanks!
~Insert Witty Quote~
-Intelligent Being
Old April 1, 2015, 10:35 AM
FreeKnight's Avatar
All the same things you'd need for another watercooling loop;
Pump, Resevoir, tube, fittings.
You might get away without having a rad since it looks like there's fans blowing on the fins attached to the card, but I don't know if it'd be worth skipping on a rad.... Probably better off to add water to your CPU as well if you're going to go through the effort of building a loop for the GPU though.
Dazmode's site has some good videos explaining the basics of what you need, how much, etc. If you're still using the Phanteks case in your specs, you should have plenty of space and options for WC IIRC.
Old April 1, 2015, 11:25 AM
SugarJ's Avatar
You'll need a rad. Having water circulate without a way to get rid of the heat in it won't help much.
I'd suggest getting a res/pump-top combo like this EK-XRES 100 DDC - Acetal - EK-DDC Series - Reservoir Pump Combo - Reservoirs & Accessories, it simplifies the loop and number of fittings. For just a GPU loop, you'll need a pump/res, rad and 6 fittings and tubing. But if you're spending that much, get a CPU block as well and 2 more fittings.
Old April 1, 2015, 12:03 PM
MuffinWRX's Avatar
Would this work if I just don't use the CPU block, and get the fittings and tubes needed to make this work?
-Intelligent Being
Old April 1, 2015, 12:51 PM
sswilson's Avatar
I'd be more inclined to recommend something from swiftech than from thermaltake....
Swiftech MCR140-X - CPU Liquid Cooling Systems CPU Cooler VGA Water Block Heatsink Pump Radiator Heat Exchanger Kit
Old April 1, 2015, 01:10 PM
Cptn Vortex's Avatar
That swiftech is a pretty nifty unit, should be fine for a GTX 780!
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old May 12, 2015, 08:05 AM
mchutch's Avatar
Swiftech has real nice all-in-ones.
Swiftech H220-X All-in-One Liquid Cooling Kit - H220-X
Old May 13, 2015, 09:02 AM
Bungwirez's Avatar
there's also that nifty new AIO-GPU setup from Alphacool
https://www.youtube.com/watch?v=nGlzRd1oAI4
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
[WTB] Asus Poseidon GTX 780 Skippman Buy/Sell & Trade 8 March 16, 2015 04:36 PM
Gallery Poseidon TheDarkLord Case Mods, Worklog & Gallery 2 May 18, 2014 03:33 PM
Asus ROG Poseidon Platinum GeForce GTX 780 SAS Video Cards 4 January 12, 2014 02:18 PM
What do you guys think? Poseidon water/air block via asus sf101 Video Cards 1 December 9, 2013 06:30 AM
Gigabyte Poseidon 310 qwerty Rumor Mill 1 November 6, 2007 02:58 PM
