Old May 8, 2008, 06:12 AM
Synth's Avatar
Default Advice on loop needed ...
Hey guys, I have the following parts and will be assembling my loop this weekend :
- Swiftech Apogee GTX cpu block
- Swiftech MCW30 chipset block
- Swiftech MCR220 radiator
- Swiftech Smart Reservoir
- D-Tek DB1 pump
- Masterkleer 7/16 ID tubing
- Primochill Primoflex 3/8 ID tubing
- 2 sets of Bitspower compression fittings (3/8) + an array of 1/2 and 3/8 fittings
Facts :
1. I am not buying a new pump anytime soon (my first watercooling setup, just wanna get my feet wet). I would probably buy an MCP355 with Petras top in a few months if I like watercooling.
2. Apogee GTX to MCW30 requires 3/8 tubing because the 7/16 kinks without the use of smartcoils, and I really don't like the look of smart coils (in my loop).
3. The D-Tek DB1 is definately not the best pump out there.
Question:
- Should I choose to setup my loop to include the MCW30 chipset block with the 3/8 tubing, will the pump struggle or will I have sufficient flow ?
or
- Should I ditch the MCW30, and do the plumbing using the 7/16 tubing?
Cheers !
Old May 8, 2008, 07:40 AM
biff's Avatar
It will work just fine putting it all together, the worst that will happen is you won't be getting the best temps possible. But if you're just getting your feet "wet" then what's it matter. I'd suggest just leaving the NB out of the loop for now. The DB1 works well in a single block loop.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old May 8, 2008, 10:31 AM
Cptn Vortex's Avatar
Who says 7/16" kinks without smartcoils? I use nothing but 7/16" tubing in all my builds and have no kinking issues, I also dont use Smartcoils.
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old May 8, 2008, 10:45 AM
Synth's Avatar
Me, because I did an initial dry build with the MCW30, on my DFI Blood Iron, and the chipset is so close to the cpu socket that I can't prevent the tubing from kinking without coils
I want a clean sexy build with tie wraps to a minimum and no coils...
Old May 8, 2008, 10:54 AM
Ah gotcha. I used 3 blue zipties in that bend just to make sure it didnt kink, but even without it did ok for me. I use the Swiftech tubing, which has quite thick walls. Yes that Masterkleer stuff is a little weaker.
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
Old May 8, 2008, 11:06 AM
Synth's Avatar
Yeah, a bit off topic, but your main build is pretty hardcore, and the Vortex solution looks super clean. Thats the build quality I'm looking for. Sleek !
Old May 8, 2008, 11:36 AM
Hehehe, I'm addicted. Re-building the loop this weekend too, got a Fusion V1 and a 3rd Rad. Also going to build a 3rd WC machine this weekend too with some left over parts lying around. Yay WC!
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
Old May 8, 2008, 09:26 PM
Default Reply
Tygon FTW! Tygon is so awesome it usually doesn't kink unless you intentionally kink it, also crystal clear so you can see the fluid flow. You could just get some barbs to fit onto the GTX, But just wondering why aren't you getting the D-Tek FuZion V2? OH ya unless you plan on extreme overclocking, I advise you ditch the MCW30.
Old May 9, 2008, 05:31 AM
Synth's Avatar
Because I already have the GTX, and the Fuzion v2 is more restrictive than the v1 (something I don't need with the DB1).
I think I'll go for a cpu block only loop, using the masterkleer. I can't believe how good the seal is when using 7/16 tubing on 1/2 fittings! For the northbridge, I'll put the spare thermalright hr-05 IFX I have lying around here somewhere.
Will post pics this weekend!
