Old May 6, 2008, 02:53 PM
Dashock's Avatar
Default Help with Setup of the Vortex Solution parts
Alright so since im still anxiously waiting for the shipment of the vortex solution to come my door step
So ive already started to think ahead on where i should setup everything in my case i know its a small case Thermaltake Matrix literally case weighs 2 pounds lightest case in the world lol i hope the radiator does not make it tilt backwards lol that would be bad lol.
Anyways here are pics of my case inside and backside.
Alright so those are my computer pics and this is what i figure is a good layout tell me if i should do different the big red blob is the pump now i know ill also have to make two holes in the back of my case im guessin ill have to cut up one of those bottoms slots and recommendations how to seal those slots.
Old May 6, 2008, 04:38 PM
Cptn Vortex's Avatar
Looks good to me! However, any way you could remove the Harddrive bays and mount them in the 5.25" bays? This will give you much more room for your pump!
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old May 6, 2008, 04:43 PM
Buy a new case or get a modular power supply.
Thats my piece of advice.
Old May 6, 2008, 04:47 PM
Dashock's Avatar
wats wrong wit the Ocz Power supply im gonna be using it for my next build its been solid for me and Vortex no i cannot take out the Hard Drive bays unfortunetely.
Old May 6, 2008, 04:48 PM
Dashock's Avatar
ill probbaly get the New Antec 1200 case but im not too found of power supplies being at the bottom of the case.
Old May 6, 2008, 04:49 PM
You could get a 590 or 690 and have twice the room you have in that case now.
My concern is I'm looking at your current case with a rats nest of wires and a antec spotcool fan and it screams "poor cooling" to me.
Old May 6, 2008, 04:51 PM
Dashock's Avatar
lol well in winter its exxelent cooling but summer yea its bad cooling i could manage the cables more probbaly and i will definetely move the spot cool fan a little more above pointed to the mofsets it keeps my video card very cool.
Old May 6, 2008, 05:32 PM
magictorch's Avatar
Just feed the psu cables into the empty top bay-tie them off with cable ties and shove them in.
There will be some tight bends with that configuration but it looks do-able. As Vortex said try and pull that drive bay out and move the drives up to the other empty bays. Will look real clean after all that.
Or just go with enaberifs case plans. BTW be careful with the screws on the rad-and touching fins-they are so delicate and its easy to run a screw through and spring a leak.
Old May 6, 2008, 06:18 PM
JD JD is offline
I think you could stick one hard drive up top there above the 5.25 bays. You could then buy an adapter kit to mount the other in a 5.25 bay.
Bundle up all the unused cables and stick them in the remaining 5.25 bays.
Then you'd have lots of space to work with I'd think.
Old May 7, 2008, 05:06 PM
Hows it going Dashock?
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
