  #61 (permalink)
Old May 14, 2008, 11:49 PM
Dashock's Avatar
You make a good point my bad! Its just the excitement of a new project and all these ideas i never knew were possible untill now! Looking thru the web it looks like with the Thermaltake Icage i can still put my grill/filtermesh on top of it i was worried i couldnt cause it stops dust from going in. Too bad i cannot use the sound dampening things that Noctua gave me on the rad instead of screws.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
  #62 (permalink)
Old May 15, 2008, 05:11 AM
magictorch's Avatar
Default Noise damper
You can still use the noise damper attachments.
Just cut the tips off and make a hole for the screw to go through..then put the dampers between the rad and fan when screwing down.
  #63 (permalink)
Old May 15, 2008, 11:24 AM
Dashock's Avatar
sounds interesting ill try it out. Well a new development as occured i was trying to figure out cable management ways and i noticed i can take the Hard drive bay out in the bottom of my case so i will go with a 5.25 i hope someone has bought the Thermaltake ICAGE before so as to i can feel comforted to the fact that this is a good quality product if anyone else has any other recommendation of the bays offcourse i will be using a fan to cool so keep that in mind.
And i hooked up the Noctua fan at 1300 it pushes air as much as my Tri-Cool at medium and pretty silent but im wondering if this will cause my temps to go up i mean with the Tri-cools i atleast have a setting to go to max and even though the sound is horrible at the full speed it pushes out an amazing amount of air but i dont know how good Antec Tri-Cools would be with my Swiftech Mcr-220 with intergrated reservoir.
Asus P5Q-E
Corsair Cx600M
