  #41 (permalink)
Old May 13, 2008, 12:17 PM
Dashock's Avatar
sounds good mate i guess the project will be on hold for another week sounds good gives me a chance to clean out ma system and how did you write all that stuff on the bottom of every one of yer messages like you have that says all your computer specs?
  #42 (permalink)
Old May 13, 2008, 12:31 PM
Dashock's Avatar
I better wait for the sponsored Ncix deals to see if theres anything on sale i could pick up i know i have to get another set of barbs, fan grills and 2 more Noctua Fans
  #43 (permalink)
Old May 13, 2008, 12:37 PM
sswilson's Avatar
Edit your signature under user CP (up top)
  #44 (permalink)
Old May 13, 2008, 12:47 PM
Dashock's Avatar
thankyou sswilson i appreciate the swift response cheers!
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
  #45 (permalink)
Old May 14, 2008, 11:09 AM
Dashock's Avatar
Benefits of using a reservoir and how can you tell which way the loops gonna push water i mean isnt the pump where the water is being pushed from the begining of the loop ?
Asus P5Q-E
Antec Spot Cool
Logitech X-230
  #46 (permalink)
Old May 14, 2008, 12:04 PM
Cptn Vortex's Avatar
A Res makes filling the loop much easier. It is a big pain using a T-line. I found myself spill a few times when I used the T-line. The downside is a Res takes up space, and is very difficult to drain. You dont need a res, because your RAD is the res. Your loop order should look just like mine. Water gets filled into the REs/Rad, flows DOWN to the Pump, then up to CPU, and back to the RAD. That is the best way. If you want the best of both worlds, add a Tline, not to use to fill, but to have there to Drain when the time comes. I would put it like in this drawing.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
  #47 (permalink)
Old May 14, 2008, 12:30 PM
Dashock's Avatar
now im gettin excited gotta make another order at direct and yea now this makes more sense thanx for the drawing
Asus P5Q-E
Antec Spot Cool
Logitech X-230
  #48 (permalink)
Old May 14, 2008, 12:37 PM
If you live near a hardware store, go to the plumbing section, they have some good 1/2 Brass T's that I use. Look nice too
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
  #49 (permalink)
Old May 14, 2008, 08:15 PM
Dashock's Avatar
have to make another order with DC ohh aboot screws id the screws for the fans to the rad were they included or am i gonna have to buy certain type since its soo delicate!
Asus P5Q-E
Antec Spot Cool
Logitech X-230
  #50 (permalink)
Old May 14, 2008, 08:16 PM
Dashock's Avatar
i dont know aboot moving the hard drives up the 5.25 bay because either way i cannot physically remove that bottom bay ill just try to hide the cables.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
