<~----> Help with Setup of the Vortex Solution parts - Page 4 - Hardware Canucks
  #31 (permalink)
Old May 13, 2008, 10:26 AM
Dashock's Avatar
Ahhh and check this out i was browsing thru the web this guy has metal inlets on his swiftech apogee gt can i do that to mine does it make a difference to the plastic lookin ones i see most people have on theirs ?
  #32 (permalink)
Old May 13, 2008, 10:34 AM
Dashock's Avatar
Metal Barbs instead of the black ones swiftech gives yea
  #33 (permalink)
Old May 13, 2008, 10:37 AM
Cptn Vortex's Avatar
It doesnt really make a difference, but Quadcore chips will benefit with the Vertical mounting because the way the Barbs line up, and the way the cores line up. Once again, we are talking about less than 1-2 degree differences here, not much at all.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
  #34 (permalink)
Old May 13, 2008, 10:41 AM
Dashock's Avatar
well looks like im going to have to do a vertical mount considering my backplate and vortex yu see the swiftech with the metal barbs on it is tat better then the swiftech barbs or should i just use the swiftech barbs.
  #35 (permalink)
Old May 13, 2008, 10:45 AM
Yes you can mount the Metal barbs onto the Apogee GT. How many metal barbs did you order?
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
  #36 (permalink)
Old May 13, 2008, 10:48 AM
Dashock's Avatar
lol id have to order more i only ordered 1 set but does it make a difference i mean like is it a safer to use that then the swiftech ones i know i have to make another order with DC i forgot to get the fan grills
  #37 (permalink)
Old May 13, 2008, 10:49 AM
Dashock's Avatar
cause the ones i bought their supposed to go on the rad right
  #38 (permalink)
Old May 13, 2008, 10:58 AM
You may as well get an extra set of Metal barbs. It will make installing and removing the tubing easier. I cut my hands up good when I broke one of the plastic ones sunday. I now despise the plastic ones, other than the fact that they are free hehehe. The metal ones are also easier to tighten and remove, as they dont sqeeze and stretch like the plastic ones.
And yes, the ones you already ordered are for the RAD
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
  #39 (permalink)
Old May 13, 2008, 11:58 AM
Dashock's Avatar
wats the size i should get the same one as the rad ones Swiftech 1/2IN Od Chrome Plated Fittings 1/4 Bspp (Set of Two).
The picture one with the metal barbs looks a bit bigger right/?
  #40 (permalink)
Old May 13, 2008, 12:00 PM
Yes, those swiftech ones are perfect. The ones in that picture are the Bitspower barbs I think they are more expensive and harder to get. Just stick with the swiftech, they work great.
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
