Old August 26, 2014, 12:36 PM
Default Radiator fans
What are some good choices for radiator fans that are quiet and smooth sounding?
I've been re-using my Scythe S-Flex E and F from years ago, and some of them are developing some chattering/scratching noises in the bearings.
Wasn't too big a fan of AP15s due to motor growl.
Looking for something with PWM so they can rev with system load... but also not looking to spend $30 per fan.
Thanks
heatware
Old August 26, 2014, 02:06 PM
fishingfanatic's Avatar
Smile Water Cooling
Well if ur doing some major mining and need good cooling Daz has those Koolance fans, though with 4 all out it's a bit LOUD! lol. Actually they have 160cfm fans for extreme cooling. The ones I have r ok, but together r loud.
Try the next ones down from the 108 cfm fans in performance cooling, or maybe they have some good fans I haven't noticed b4.
I have been using the Gelids 75 cfm/fan. Changed all of my sealed wcing units to those for increased performance and significantly reduced noise. I always keep noise in mind when selecting fans as well as cfms.
They work real well and compared to the factory fans are much quieter with twice the air flow. Some of those factory supplied fans r absolutely terribly LOUD like the ones that come with the Silverstone Tundra.
They're using metric instead of cfms, and these were about 125 give or take. The ones at Daz r listed as cfm.
His prices were a lot cheaper as well compared to most.
Hope that helps a bit.
FF
Old August 26, 2014, 07:15 PM
Bungwirez's Avatar
whatever fans you end up using, I would also add one of these ... helps reduce noise/vibrations.
https://www.dazmode.com/store/produc...1mm-thickness/
Old August 26, 2014, 07:20 PM
Mena's Avatar
Check out the Cougar Vortex fans. They come in Pwm and three pin versions and have served me well and quietly.
I am watching you.
For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.
When a ladder was stolen from a store the manager said that further steps would be taken
Old August 27, 2014, 01:23 PM
10e's Avatar
10e 10e is offline
They're not PWM but the BeQuiet! Silent Wings 2 have super quiet motors and don't get loud with radiators. They also have built in quieting mounts
http://www.ncix.com/detail/be-quiet-...80363-1360.htm
They have the Pure wings too, but they have a different type bearing and I've not tried them.
As Mena mentioned, the Cougar Vortex PWM fans are also pretty quiet.
BitFenix Spectre Pro fans are quiet too, but I find they don't push nearly as much air as the Be Quiet! or Cougar fans.
Old August 29, 2014, 06:15 AM
Thanks for everyone's input. After looking at some more reviews about the Cougar PWM fans I ordered 5 for $6 each from NewEgg, thanks to Prolab for pointing them out. Threw in a couple of Rosewill PWM fans as well since the reviews said they are underrated and are very quiet.
heatware
Old September 4, 2014, 06:38 AM
Skippman's Avatar
Any thoughts on the Corsair fans?
Old September 4, 2014, 08:52 AM
TTC TTC is online now
Get em yet ?
Old September 4, 2014, 09:01 AM
I received my fans on Tuesday but haven't had any time to power them up.
SPCR review on the Corsair fans were unfavorable so I deliberately avoided them, even though they look great.
heatware
Old September 4, 2014, 09:15 AM
Skippman's Avatar
The Corsairs at the BitFenix are on my short list. Link to the review?
Help. Need new fans for my radiator. ss7900 Water Cooling 0 November 26, 2013 12:52 PM
Low RPM fans on a High FPI radiator bigFOIG Water Cooling 12 January 10, 2012 05:32 PM
[WTB] LF: 3x12 Radiator, 1366 WB, Pump, QUIET fans, tubing, fittings, res n-sanity Buy/Sell & Trade 0 December 14, 2011 01:24 PM
Q: Radiator and Fans matari Water Cooling 5 July 13, 2011 09:00 PM
Fan Controller for Radiator Fans AmuseMe Water Cooling 13 May 17, 2010 07:10 AM
