Old July 30, 2014, 06:45 AM
Closed Note's Avatar
Default Tube Clouding/Fading - How to prevent?
Hello everyone :)
haven't been around for a while. Recently I noticed my tubings were fading, the coolant itself looks normal when drained. My question is, is there any way to prevent tubing from fading or do I have to replace my tubing every now and then, perhaps go with a better brand?
This is what I'm using:
Mayhems Pre-Mix X1 UV Red
Masterkleer tubing PVC 19/13mm (1/2"ID) clear
Thanks in advance for your help! ^^
Edit: the tubing setup is more or less half a year old in case this info is needed
Old July 30, 2014, 08:03 AM
lowfat's Avatar
Try Primochill LRT Advanced. It is the best but it can still yellow/stain easily depending on the loop. IMHO the only way to truely not have this issue is by moving to acrylic.
Mael
Big Lian Li
Forever Alone
Old July 30, 2014, 08:32 AM
thanks lowfat i'll have a look at the primochill tubing! :)
Old July 30, 2014, 09:04 PM
WhippWhapp's Avatar
Meant to suggest Norprene.
I rub and whack and choke and stroke!
Old July 31, 2014, 06:54 AM
Dazmode's Avatar
IMHO the only way to truly not have this issue is by moving to acrylic.
+1 This.
Orange Build: Final Video
HTPC Build: Final Video
Old July 31, 2014, 08:50 AM
lowfat's Avatar
Originally Posted by WhippWhapp View Post
Or tygon...
Tygon R3603, B-44-4X, and B-44-3 all have clouded up on me.
Mael
Big Lian Li
Forever Alone
Old July 31, 2014, 09:42 AM
I have absolutely no experience with acrylic tubing, and just thinking of taking apart that kind of loop .. ^^; I wouldn't even know where to begin.
I've looked up some reviews of the PrimoChill Advanced LRT, they seem very resilient to the heated water that seems to cause the fading/staining, so I will definitely get those for the next maintenance :) thanks for the recommendation!
Old September 24, 2014, 08:35 PM
Ashihtaka's Avatar
I second Primochill LRT. I've tried feser one and it turned cloudy within a month. This Primochill shows no sign of clouding after a month of use so far.
Old November 18, 2014, 04:50 PM
Ashihtaka's Avatar
Update after two months, Nevermind. Primochill advanced LRT clearly clouds as well. I've been using swiftech hydryx pm coolant with nothing else, and my new tubes have definitely clouded up.
Acrylic is the ONLY true way as of now to avoid plasticizer/clouding.
Old November 18, 2014, 05:26 PM
Sagath's Avatar
Water or any other fluid has a (grit?) raiting, regardless of how smooth you think it is. Sooner or later it will score tubes, and cause them to cloud. You need something harder then water, as funky as that sounds, for the water to not 'damage' the tubes. This is why acrylic wont cloud with water.
Originally Posted by Lpfan4ever View Post
AKG shot the hamsters, and then Perineum drove his Mustang with summer tires into the server.
ST31000340AS... Any way to prevent it from sleeping biggyk Storage 7 June 22, 2012 02:01 PM
Keeping your cool: a guide to prevent your rig from overheating Sam_Reynolds Guides & How-to's 3 May 10, 2011 01:33 AM
prevent standard user account from installing programs freaked O/S's, Drivers & General Software 3 June 21, 2010 08:47 AM
AMD chipset AHCI drivers prevent boot on SSD? sswilson Storage 20 June 3, 2010 07:40 AM
What can I do to prevent damages to a laptop? appplejack Mobile Computing 3 May 29, 2009 11:17 PM
