Old July 4, 2014, 08:38 AM
rjbarker's Avatar
Default Swiftech 8 Way PWM 4 Pin Splitter Box - Query
Hey Guys...
Got this...
8-Way PWM splitter box - Rouchon Industries Inc., dba Swiftech - PC Liquid Cooling Systems CPU Cooler VGA Water Block Heatsink Pump Radiator Heat Exchanger Kit
Found it in my pile of spare parts....can I use this to connect 8 PWM Fans to 1 Channel of my FC9 Fan Controller?
The FC9 Controller is a 3 Pin only...BUT it is 50W on a single channel and I'm pretty sure I can plug the 4 Pin in.
I'm thinking it should be okay and I would simply plug the 4 Pin that would go to the Mobo Header into the Fan Controller.....should be able to go 4 Pin to 3 Pin......and I'm sure I dont have to plug the SATA Power Connector in as plenty of power being provided by Fan Controller (Fan Controller is plugged into 3 12v Molex Connectors).
I would certainly rather use this than all my Splitters :)
Thanks.....likely try it...cant see any major problems if it dont work.....I'm trying to get my final 2 Fans on my RX 480 Rad for 8 Fan Push / Pull....n clean up the Fan Cabling (eliminate splitters)..
EDIT: Little more digging and everything I read online says it wont work....oh well...more splitters it is....
Firestrike Extreme: 21.452
MARK 11: 32.530
HDMI splitter from PC? sswilson HTPC Systems & Software 11 January 9, 2014 06:22 PM
3 pin fan splitter cables, or fan splitter station (bitspower, fractal etc)? Sheep Air Cooling 4 August 28, 2012 10:19 PM
[WTB] 3-pin Fan Splitter (3-way) tragd Buy/Sell & Trade 4 September 19, 2010 12:09 PM
[WTB] (GVR) 3 pin Y Fan Splitter & RAM Sinks jcmaz Buy/Sell & Trade 3 April 21, 2010 04:17 PM
CPU Fan Splitter Plug FreeKnight Air Cooling 5 February 8, 2010 09:53 AM
