Old June 18, 2014, 02:45 AM
reaverclan's Avatar
Default Should I drain immediately?
Hi haven't been around for awhile, anyways I'm back for a quick question. I have gotten into water cooling with a xspc ray storm, rx360, and d5 res combo kit. my question is this, I did not hear about flushing the rad till i already started the leak testing phase. my loop is currently doing just that and I want to know if i should stop it and drain it all then flush the rad of if i leave it for like 3 months will it damage something or just degrade performance. I hope this makes sense.
rvcjew
Old June 18, 2014, 03:35 AM
KaptCrunch's Avatar
degrade performance and muck up the loop depends on amount of flux left over when made
when flush rad also open all blocks an clean , before open them
have spare 0-rings to replace for assurance of no leaks after
Old June 18, 2014, 04:49 AM
akira749's Avatar
rvcjew
In some way you're lucky because XSPC are usually "almost" clean from the factory compared to Alphacool/Phobya rads.
But since you're still in leak testing, I would flush the loop, remove the rad and and clean flush it by doing 3-4 "shaking dance" runs. After that, just reconnect the rad in the loop, refill with DI water and run it a few minutes (5-10 minutes) and flush the loop again this is just to clean the potential residues. Then fill it up again and re-start your leak test phase.
Old June 18, 2014, 01:32 PM
reaverclan's Avatar
I decided to wait a little and unless it's inside all of the block I see none in my res anywhere, I don't have time to drain it now but will see how it goes thanks for the advice. Duely noted to get a spare oring.
Rvcjew
Old June 18, 2014, 10:02 PM
rjbarker's Avatar
Anyone know where we can get spare O Rings for EKWB's....in particular the FC GTX 780Ti model...does Daz carry em or from EK direct?...curious..
Firestrike Extreme: 21.452
MARK 11: 32.530
Old June 19, 2014, 03:48 AM
akira749's Avatar
In North America, FrozenCPU is the official place for EK replacement parts like this.
The one you want to have for your specific block is this one : EK Replacement O-Ring - 144 x 2.0 (OR 144x2 NBR55)
Old June 23, 2014, 09:07 PM
Bungwirez's Avatar
oh nice Akira. IDK this.
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old October 17, 2014, 09:19 PM
reaverclan's Avatar
Well it finally got drained and omg yeah had lots of flux in block, basically it was plugged. I flushed the radiator and replaced tubing as it was coated it what ever this is on my inside of where pump goes in the res. Any idea what this powder like stuff is? us it my pipes reacting to the flux or biocide?
Thanks,
rvcjew
Block before cleaning.
Old October 17, 2014, 10:09 PM
that's brutal man... I've never seen anything like that before. What color is your tubing?
Mah Rig now
Mah Rig before
My stuff for sale.
Old October 18, 2014, 12:13 AM
reaverclan's Avatar
Heh yeah it is. its all good now it was the dead water i used apparently according to very respected friend who knows this stuff really well. it reacted to my tubing and is not what you use for my kind of blocks I guess. Frozen cpu gives it free with stuff so i took it but it was a mistake i guess, i will be going straight distilled till i get some PT nuke. My system now has new tubing and i added a non bay res and gpu blocks so its all good now I will fill it tomorrow and bleed it leave feedback. it seems to be oxidation from the reaction of the biocide and thats it. The black was defiantly Flux though lol. This is a good example of needing to flush before hand.
This is what was in my loop IandH Dead-Water Copper Sulfate Biocidal PC Coolant Additive - 15 mL - FrozenCPU.com and i was told this was bad and is what is reacting to do this also it reacting to the flux didn't help i'm sure.
New setup with OLD D5 and Ek top
OLD setup
HP Agrees to $425,000 Civil Penalty for Failure to Immediately Report Li-Ion Battery Sam_Reynolds Press Releases & Tech News 0 January 24, 2012 04:48 PM
[Likely not virus?] MSE, Windows Defender, Firewall close immediately on startup frontier204 O/S's, Drivers & General Software 5 April 14, 2011 11:39 AM
WTB Immediately HD3870 Eldonko Buy/Sell & Trade 19 November 6, 2008 12:28 AM
drain???? WolfBane Water Cooling 29 July 13, 2008 09:10 AM
Need help Immediately choosing ram mailaw RAM 5 July 25, 2007 10:29 AM
