Old June 13, 2014, 03:14 AM
biff's Avatar
Default Worthwhile Rad Upgrade?
Currently I have a Cosmos chassis that has a dual loop WC setup. I'm still running an old Q6600 @ 3.6GHz. The CPU is on it's own loop and is cooled by a lowly swiftech MCR220 with some coolermaster generic fans, though they are dying and I just got some GT 13's to replace them. This setup deals with the Q6600 fine but I will be upgrading to a 4670k or 4690k before too long. I was thinking on trading out the MCR220 or an alphacool XT45 240mm rad. I think the 60mm version is ~5mm too big without running into MB clearance issues.
So I guess the question is, is the XT45 rad a worthwhile upgrade over the MCR220? Or is it a necessary upgrade to be able to handle a 4670k or 4690k? FWIW I will be OCing the new chip but probably wont go to crazy with it.
Thanks.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old June 13, 2014, 05:42 AM
lowfat's Avatar
Nope. There won't be a noticeable increase in cooling capacity. Maybe a 1 degree improvement in temps.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old June 13, 2014, 06:44 AM
biff's Avatar
Figured it would be minimal returns. Thanks for the reality check. Just saw a bit about using rigid acrylic tubing and kind of has me inspired to do a replumb of my system, you think that MCR 220 will be able to handle a 4670k or should I try to shoehorn in a 3x120mm (or 2x140mm) while I'm there?
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old June 13, 2014, 07:02 AM
Sagath's Avatar
A 220 is lots of cooling for a 4670 even if you max the OC out. Ive had a nV 280, i7 920@4ghz+ and EVGA X58 motherboard block all on a triple without issue.
Old June 13, 2014, 08:02 AM
Bond007's Avatar
A Q6600 would put out more heat than a haswell CPU.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old June 13, 2014, 08:46 AM
biff's Avatar
Looks like I'm golden then. Thanks.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old June 13, 2014, 06:53 PM
a q6600 have a TDP of 105w
while a 4690k have 88w
Old June 16, 2014, 09:38 PM
rjbarker's Avatar
Another option of thicker Rads is the XSPC RX ver 3 that are relatively new models from version 2....they are 56mm thick, so a little thinner than the UT60's....I can get one in the top of my 900D with push / pull Fans and it "just" clears the EPS 12v connectors on the top of the RIVE.
Great reviews for this Rad as well..
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Is it worthwhile trading my iphone 4 32gb for... Nodscene Mobile Computing 4 October 14, 2012 08:04 AM
Keep my 920 or Upgrade to A 970? Goalieman077 CPU's and Motherboards 14 December 23, 2010 01:51 AM
VGA upgrade from GTX 260 first, or CPU+mobo upgrade first? panzerfan Video Cards 9 April 6, 2010 08:25 PM
4870 512mb to GTX 280 a worthwhile upgrade? Ging9 Video Cards 8 April 1, 2009 05:28 AM
Odds on a worthwhile step-up from 8800GT in the next 90 days? rommelrommel Video Cards 2 February 1, 2008 10:29 AM
