Old May 27, 2014, 09:26 PM
Prolab's Avatar
Default Unable to read RPM's on MCP35x2
Hey guys/gals
Im having issues with my pump. For the last few days, my RPM readings have been wonky. Most times it will show up and i can read the RPM's, but occasionally it'll drop out - AI Suite, Openhardware monitor and the BIOS will report that its ZERO.
Currently the pump is connected to the CPU_FAN header.
So i started troubleshooting:
- Switched the connections to OPT_FAN. Still ZERO RPM (Both on BIOS and AI Suite).
- Plugged a stock corsair fans to CPU_FAN and OPT_FAN. I can read its RPM (Both on BIOS and AI Suite).
- Plugged another fan to both headers, i can read its RPM (Both on BIOS and AI Suite).
- I unplugged the pump and let it run on the 4-pin molex. I can feel the pump vibrating and goes to full speed.
- I plugged it again on either PWM header - and i can feel the pump slowing down. I unplugged it again, and i feel it running full speed.
So i know the pump is working. I also downloaded Speed fan and it reports ZERO rpm.
Is my pump dying?
Gaming Rig:
-Caselab STH10, Swiffy MCP35x2, (2) Aphacool UT60 480 rad, HWL GTX 360, Heatkiller IV, i7 5930k @ 4.5 Ghz, 16GB Ripjaws, Asus X99 Deluxe ii, (2) XFX R9 290 w/ XPSC WB, 240 GB Intel 530, 500 GB 850 EVO, (6) 3 TB Tosh HD, EVGA G2 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.0 Ghz, Asrock Z97 Pro 4, Asus 290, 128 GB Crucial M4, (2) 2 TB WD Green, (1) 2 TB Sammy F4, (2) 5 TB Tosh HD, Enthoo Primo, XSPC 480, 240 HWL GTS, Corsair HX620, Win 10 Pro
Old May 27, 2014, 10:02 PM
Bungwirez's Avatar
just a thought, maybe solder on the tachometer wire at the PCB is fried...
I've had this pump overheat and the PCB melt, particularly in a dual DDC config.
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old May 28, 2014, 10:02 AM
Prolab's Avatar
Eh most likely.
I already contacted swiftech about it. It seems like i have to warranty my pump to get it working again.
Thanks!
Gaming Rig:
HTPC Rig:
unable to do 1080P from PC on my TV Alpine Display Units 6 September 17, 2013 05:38 AM
Unable to acccess Google? Lpfan4ever Off Topic 12 August 12, 2009 08:21 PM
unable to OC BrokenHalo83 Troubleshooting 8 April 6, 2009 11:09 AM
Problem trying to get 'Read Only' file not Read only! bushwickbill Troubleshooting 5 August 10, 2008 12:41 AM
Unable to overclock Computergeek Overclocking, Tweaking and Benchmarking 1 July 11, 2008 04:17 PM
