Old May 5, 2008, 08:27 AM
Dashock's Avatar
Default Distilled water spills can short out computer parts??
Alright hey guys so im wondering whats the best coolant to use for WC that wonnt short out computer parts say if i have a leak and distilled water and Swiftech Hydrx drops into the video card for example will it short it out?? IF so what would be the best coolant to use doesnt matter price but would not short out parts thanx.
Old May 5, 2008, 08:37 AM
Dashock's Avatar
im lookin at reviews and such aboot the liquids like Feser One and ill probbaly not be switchin the liquids on a regular basis if that helps
Old May 5, 2008, 08:58 AM
ChuckleBrother's Avatar
From everything I've read, even a non conductive fluid won't be perfect, so instead of going for something thats safe, just go for top performance and take the proper precautions to keep your loop watertight(small tubing on 1/2" barbs, ziptie or clamp your tubing around barbs, thoroughly leak test with your machine powered OFF and unplugged).
"...you play a mean banjo"
Old May 5, 2008, 09:56 AM
Dashock's Avatar
AHH I Guess ill go with distilled water and Hydrex
Old May 5, 2008, 10:50 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
It all comes down to your comfort level. Feser One looks amazing and is non conductive. BUT Tygon 7/16 ID tubing over Danger Den Custom high flow barbs (or perfect seal's if your a sucker for punishment but provide even MORE secure fitting) that is then steel worm clamped or double zip tied...is hard to beat as well. Personally, I went for BOTH in the system I recently built (after all my rep was on the line ;) ).
Old May 5, 2008, 11:14 AM
Cptn Vortex's Avatar
Just do Distilled and the Hydrx if you already have it.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old May 5, 2008, 11:29 AM
Dashock's Avatar
yea still waitin for Direct canada to ship the stuff and btw i bought the Noctua fans over yer Scythe man every review i saw said the Noctua was better except in price and i dont mind paying more for a little better with quietness. I only bought 2 as i have two antec tri cools i can use im gonna use the Noctua to Push and antecs to pull hope that config is good.
