Old May 21, 2014, 09:41 PM
sf101's Avatar
The xspc RX line is great for the price. i have a few RX and the slightly thinner "mid thickness" AX rads in my loop they work great.
My 5 Current Rigs-Guest-Main-Work/Spare-HTPC-Laptop
I7-6700T-Work
3770K@ 4.8GHz -Main
2500k @ 4.7GHz -Guest PC
3570K @ 4.5 -HTPC
MSI GT70-2OC/770m-998/4800MHz -Laptop
SF101 HW BOT
Crossfired XFX290X@1150/1500mhz-EKWB (Main)|GIGA-OC7970WF3@1250/1850 (HTPC)
MSI 970GTX (Guest) ||Asus480GTX@900/2000 (work)
Old May 21, 2014, 11:29 PM
I've used those feser fittings before I didn't have any issue with them. Even though Daz might be a bit more than some other retailers like frozen cpu. You won't pay duty fees and extra shipping costs etc. Your second option is to buy used fittings which generally isn't an issue IMO and way cheaper. Fittings last a long long time. Take your time figuring stuff out so you only have to pay shipping once or twice :)
I had to google your rad I didn't realize what you were using at 1st. All clear now ;-)
Mah Rig now
Mah Rig before
My stuff for sale.
Old May 22, 2014, 02:07 PM
CORE's Avatar
Hey guys,
Are swiftech rotaries good? I am just afraid that a leak might occur. I've read alot of forums and the consensus is always get bitspower.
Old May 22, 2014, 02:36 PM
lowfat's Avatar
Originally Posted by CORE View Post
Hey guys,
If you aren't in a hurry look on Ailexpress for 90 degree rotaries. These are the highest quality black rotaries that i have found.
High quality Black G1/4'' thread 90 degree Rotary Fitting Adapter Rotating 90 degrees water cooling Adaptors-in Fans & Cooling from Electronics on Aliexpress.com
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old May 22, 2014, 02:54 PM
CORE's Avatar
@ lowfat: these are good? Its eerily similar to bitspower.
One question guys. I have an Asus R4E. I am using 2 gtx 780 lightning in SLI. They are at the lane 1 (x16) and lane 4? (x16). Do i need the terminal triple serial for the EK FC terminal for it to connect (with a blank)?
Is this the EK-FC terminal that I need for it to connect? Here is the link: https://www.dazmode.com/store/produc...triple-serial/
Old May 23, 2014, 07:19 AM
bitspower is pretty much top of the line and if lowfat recommends them they are good dude. If you are trying to save money get one of these instead. You can build this with tubing too and it works fine. The temp difference between cards will be a degree or 2 and will not adversely affect performance in any way. I prefer the one pipe system over the series system personally. Conversely you can always just use 2-4 compression fittings and tubing instead of that sli block.
I think tubing looks better than those blocks anyway.
Mah Rig now
Mah Rig before
My stuff for sale.
Old May 23, 2014, 07:38 AM
lowfat's Avatar
Similar to Bitspower. The paint is more blacfk and there are no silly huge golden logos all over the place. These are the only 90s I will allow in my builds.
Queen of Dreams WIP
Big Lian Li
Complete
sswilson's Avatar
Have you had any issues with customs ordering from this particular vendor? So far my only orders from Chinese online sources have been small and come through CP without any duties at all.
  #19 (permalink)
Old May 23, 2014, 07:50 AM
CORE's Avatar
@ lowfat: thanks for that info!
I contacted the seller and got them from her. (I can wait for this to ship since my gpu blocks are available 2-4weeks from NCIX)
@clshades: I was thinking of doing that too since it will save me roughly 40$ from buying the bridge and blank. Now, I just can't wait for my shipments to arrive
  #20 (permalink)
Old May 23, 2014, 07:52 AM
CORE's Avatar
@sswilson: I contacted the seller through live chat and she was pretty responsive. I got 12x straight 3/8 x 5/8, 4x 90deg rotary, and 4x 45deg rotary for 123$ shipped. I think this was a decent amount since the "Barrow fittings" are supposedly oem of bitspower (according to various forums).
Questions about OC on i7-4930k Warcrimes Overclocking, Tweaking and Benchmarking 15 April 29, 2014 09:19 PM
Intel i7-4930K & i7-4820K Review Comment Thread SKYMTL CPU's and Motherboards 39 September 13, 2013 09:57 AM
Socket 2011 n Ivy Bridge E 4930k / 4960X rjbarker Rumor Mill 20 May 11, 2013 05:25 PM
MSI Announces New Lightning Series Graphics Card N275GTX Lightning FiXT Press Releases & Tech News 0 August 14, 2009 11:03 AM
