Old May 9, 2014, 02:01 PM
Warcrimes's Avatar
Default Should i change tubing?
I've always used DI and a silver and 2 weeks ago i decided to try some pre mixed color. I decided to go back to DI and just use Mayhems X1 dye and i was wondering if i should change my tubing before adding the new fluid. Ive never used dyes either so excuse me for the questions. My dyes will arrive tomorrow should i mix it before adding it or just add drops like if i were adding PT nuke into the res? Thanks
Old May 9, 2014, 05:00 PM
Bungwirez's Avatar
depends how long your loop has been running and what tubes you used.
personally, I would go out and get new tube regardless, cause rebuilding loops is fun,
and Mayhems can be fussy - it really likes fresh, clean systems from the get go.
as for adding the X1, i've seen it go either way. drop it in the rez, with pump running, till you get the color you like,
or for if you know the volume of liquid in your loop, you can premix the concentration in a beaker.
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old May 9, 2014, 08:37 PM
lowfat's Avatar
What kind of tubing and what colour dye? You generally do not want to use any other antimicrobial when using dye. It will affect the PH and may affect the colour of the dye.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old May 10, 2014, 12:24 AM
Warcrimes's Avatar
It's been running 2 wks. I just opened it up. The tubes are already stained. I have extra tubing here from when I built it.
So not recommended to have silver with the x1 dye?
Part of me wants to just stick to just pure distilled water. But I really want to experiment with dyes finally.
I normally run my loop 3 times and 3 drains before I add the final distilled water that would stay. Any recommendations for cleaning up to premixed fluid that was in there? Besides waiting for it to be clear. Should I run a 80/20 vinegar through it? Any tips on this would help. I'm really new to premixed and dyes
Old May 10, 2014, 02:30 AM
KaptCrunch's Avatar
best use color tubing if want color
and not use vinegar at all in loop
Old May 10, 2014, 07:07 AM
lowfat's Avatar
What brand of tubing?
Make sure you wash the radiators out well.
If you use vinegar then you need to was out with baking soda to neutralize the acid. Then rinse thoroughly with distilled.
Queen of Dreams WIP
Big Lian Li
Complete
Old May 10, 2014, 08:04 AM
Warcrimes's Avatar
I'm trying out xspc for the first time I've always just used Tygon tubing.
Old May 10, 2014, 09:02 AM
lowfat's Avatar
Try to find a bottle brush and clean out the tubing if possible. There could be plasticizer buildup.
Queen of Dreams WIP
Big Lian Li
Complete
Old May 10, 2014, 10:36 AM
Warcrimes's Avatar
I'm replacing it. I'd rather not cheap out for saving tubing
Old May 10, 2014, 06:03 PM
Stay away from dyes, they discolor everything. I stopped using dye in favor of colored tubes. I prefer the Primo tubing myself.
Red Sleeved Tubing vs Clear Tubing with Red Dye Keyz Water Cooling 9 February 24, 2014 12:53 PM
Primochill Tubing or any good tubing with thick walls in Vancouver Lower Mainland? bjornbjorn Water Cooling 5 January 26, 2012 05:19 PM
Red Tubing? Amarthfea Water Cooling 11 August 27, 2011 05:51 PM
Where to buy WC tubing? sinn98 Water Cooling 8 August 24, 2009 06:55 AM
Tubing, tubing... what to choose? Dazmode Water Cooling 16 June 23, 2009 02:32 PM
