Old May 4, 2014, 11:10 AM
Lpfan4ever's Avatar
Default Purple Tubing - 7/16ID 5/8OD
Seems like a long shot, but I'm looking to switch up my white tubing for purple tubing for my next rig update. I'm using 7/16ID 5/8OD tubing right now and do not want to switch since the last bunch of compression fittings I bought cost me an arm and a leg.
The question is: Does anybody tubing like that in Canada? The only places I can seem to find it easily are in the states and basically double the item cost for shipping, not to mention possible import fees/taxes. (Aquatuning.us, PerPCs, etc)
Originally Posted by encorp
Code:
<firebane> slightly used
Old May 4, 2014, 11:23 AM
sswilson's Avatar
Are your barbs 7/16" or are they 1/2"? You'll probably have a much easier time finding 1/2" tubing and I was under the impression that 7/16" tubing was being used on 1/2" fittings for a tighter fit.
edit: NVM... I see half" tubing is typically 3/4 OD as opposed to 5/8"
Daz has some but not in purple... did you drop him a line to see if he can get any?
Old May 4, 2014, 11:43 AM
Lpfan4ever's Avatar
They are actually 7/16 5/8 compressions. Odd size, I know, but it was my decided compromise coming from the gargantuan 1/2 3/4 stuff I was using before.
I have not asked Daz, figured I'd bother him on Monday instead of on the weekend.
Code:
Old May 5, 2014, 11:53 AM
10e's Avatar
10e 10e is offline
If you order 4 feet or less from FrozenCPU you can get it shipped via USPS for $7.99 USD, and I'm 87.34534% sure you won't get dinged for taxes/duties. That's probably your best bet to avoid egregious shipping charges unless Daz can help you.
Any more and you'll have to pay more than double in shipping from them. I avoid PPC most of the time because of their distance and higher shipping costs to Canuckistan.
Old May 5, 2014, 02:25 PM
chrisk's Avatar
Folding Captain
That box of goodies coming from Ontario to Calgary has a plethora of compression fittings. 1/2"ID - 3/4"OD is the size.
Fold for team #54196
Old May 5, 2014, 09:00 PM
Lpfan4ever's Avatar
I found some compromise/potential awesomeness when browsing through Daz's clearance stuff. Should cover both of my desired colours.
Code:
Old May 6, 2014, 03:26 AM
sswilson's Avatar
Did you decide on the blue?
Red Sleeved Tubing vs Clear Tubing with Red Dye Keyz Water Cooling 9 February 24, 2014 12:53 PM
-The Purple Machine - GeneralChaos13 New Builds 3 November 10, 2013 09:45 PM
Primochill Tubing or any good tubing with thick walls in Vancouver Lower Mainland? bjornbjorn Water Cooling 5 January 26, 2012 05:19 PM
5/16ID, 7/16OD tubing useless? donimo Water Cooling 5 January 14, 2009 01:20 PM
Purple Hue on LCD the_bandit87 Troubleshooting 2 February 28, 2008 03:43 PM
