Old April 27, 2014, 04:03 PM
rjbarker's Avatar
Default Procyon II - Liquid Cooling Complete
So thats it...leak tested for 20 hrs...all good...little tiny air bubbles stuck to inside of Reservoir glass dont seem to be accumulating anymore...I'll continue to monitor
All hooked up again and booted up fine...CPU and GPU's still OC'd to what they were when I disassembled:
CPU 4.8 Ghz @ 1.35 v (under full load)
GPU's +130 Mhz Core +200 Mhz Memory - Boosts to 1202 Mhz
Quick 20 minute session of LinX - Max Core Temp 62c...about a 15c drop from Swiftech H320 AIO
Quick 20 minute session of Batman Arkham Origins...VSinch Disabled
Framerates steady 130 FPS...both GPU's 98% utilization...1202 Boost Core:
Max Temps: GPU#1 40c GPU#2 37c - thats about a drop of 40c !!!
Best of all, all those fans running at about 50% just a "hush"....sweet!!!! No screaming GPU Fans and obscene Temps!!
The Vario D5 is running at #2 approx. 2500 RPM..
Grand total of 16 Fans all running off of my 4 channel FC 9 Controller:
Channel 1 - 3 Peneatrators front intakes
Channel 2 - Top rear 140mm Corsair AF Series Intake (this one I'm going to swap out for a Noctua )
Channel 3 - 6 Noctua NF F Series push / pull bottom Rad
Channel 4 - 6 Corsair SP Series push / pull top Rad
Anyhow, pretty stoked and impressed, now I understand why you WC'ers dont hesitate to go this route.....and I had fun building!!
Thanks to all those providing me with insite!!
I'm not much of a photorapher, but here's a few completed shots.....I didnt bother with the UV Cathodes, to anxious to see how it would run!!
(old RIVE n 3930K)
Firestrike Extreme: 21.452
MARK 11: 32.530
Old April 27, 2014, 04:40 PM
sswilson's Avatar
Sounds like everything is working as advertised, and that you've enjoyed both the outcome and the journey.
Temps sound great (don't forget the delta from load to idle tems.... ;) ), and it sounds like you've got a substantial improvement in sounds levels as well.
So, should be start a new "office" pool on the exact date you break it down to add new shiny bits, and/or how many times you do that over the next 6 months???? :)
Welcome to the world of wet!
Old April 27, 2014, 04:56 PM
rjbarker's Avatar
GPU's id;e at 21 and 22c
CPU sitting 26 - 30c on all 6 Cores
Yep....how about a mod kit for D5 Vario ;)
(old RIVE n 3930K)
MARK 11: 32.530
Old April 27, 2014, 04:59 PM
KaptCrunch's Avatar
the d5 is to strong for that rez inlet size set-up
as you see in pic's
pure cavitation happening in rez, set to #1
great build, I didn't want to rain on your nice work jbarker but the res-d5 has issues as it sits
so how it going to the wet side of gaming
Old April 27, 2014, 05:12 PM
rjbarker's Avatar
^^^ From what little I tested....if I can game with that kind of silence and Gpu Temps in the mid 40's that in itself made it totally worth it..
I turned the Pump right down to the lowest it will go...so will keep an eye on it.
I would think provided my temps are good...the bubbles to accumulate too much I sould be okay until I drain and reconfigure (I'll get rid of the 90's going in / out of the Res) ?
Cheers
(old RIVE n 3930K)
MARK 11: 32.530
Old April 27, 2014, 05:17 PM
KaptCrunch's Avatar
out is fine just inlet's no 90's
use a syringe to drain and save your fluid
Old April 27, 2014, 06:24 PM
rjbarker's Avatar
So just clarify.....(and I'd like to stick to Fittings of the same make / brand)....this Y Connector
https://www.dazmode.com/store/produc...adapter_black/
Coming from my Rad....(I can re-orientate the Rad so a straight run to the Res (sort of)....then split to 2 outgoing tubes to both Inlets of the Res....right? I could increase the size of the tube from the Y connector to the Inlet Ports on the res if need be as well.....
(old RIVE n 3930K)
MARK 11: 32.530
Old April 27, 2014, 06:39 PM
KaptCrunch's Avatar
your making a manifold for inlet for D5 suction is not matching 1 inlet
with above your still same port size with 3/4 hose is increasing area to support D5 suction
2x https://www.dazmode.com/store/produc...itting_-black/
to pump inlet
guaranteed you won't cavitation with this mod
Old April 27, 2014, 08:18 PM
rjbarker's Avatar
^^^ Okay I see where your going....there wouldnt be much room between the Rad and the Res intakes for all that..I would have to come off of a Rotary 90 (2x 45) from bottom of Rad....then to 2 x inlets on Res....would it be beneficial even just to go from the 90 from Rad (remember I'll end for end the Rad from its current position to allow for more length to Res), then to the Y Connector...then 2 x 3/4" OD 1/2" ID to both inlets?
Essentially exactly as your showing minus the 3/4" OD 1/2" ID length before the "Y Connector".... I could probably get 2 lengths each around 5 - 6" in length 3/4" OD 1/2" ID to res....this would allow me to have the "manifold with Y" off of lower outlet of Rad....then 2 decent lengths of 3/4" OD to res......this make sense..? Guess it would be an improvement and reduce cavitation?
And as it stands I would still have to have one of the two Res Inlets with a 45 (maybe a 30) on it....no way around that...
(old RIVE n 3930K)
MARK 11: 32.530
Old April 27, 2014, 09:18 PM
This is the main reason why I water cool... enjoy it man!
Mah Rig now
Mah Rig before
My stuff for sale.
Procyon Going Liquid rjbarker Case Mods, Worklog & Gallery 3 April 26, 2014 02:34 PM
Completed Old liquid cooling build Kartner Case Mods, Worklog & Gallery 17 November 29, 2013 01:05 PM
Best Liquid Cooling For COSMOS II CHICKEN_jr Water Cooling 2 April 3, 2012 08:33 AM
TEC liquid cooling. Overclocker~4.1 Water Cooling 14 September 24, 2009 07:16 PM
Dry Ice and Liquid Cooling? CanadaRox Water Cooling 13 December 27, 2008 08:27 AM
