Old April 23, 2014, 03:23 PM
SAS SAS is offline
Default XSPC WaterBlock for 780 will work on 780ti?
I am wondering if the standard waterblock for the Titan/780 from XSPC will fit and work on a reference 780ti? Or are they 2 different blocks that seem the same?
XSPC Full Cover Razor GTX Titan / 780 [XS-GTX-TITAN] from XSPC Online Store
XSPC Full Cover Razor GTX Titan / 780 / 780Ti Waterblock [XS-GTX-780TI] from XSPC Online Store
I have a source that sells the Titan/780 block but will it fir the 780ti?
Old April 23, 2014, 03:44 PM
lowfat's Avatar
They do not show a picture of the bottom of the acrylic piece that covers the entire pcb. I would say you more than likely would need to modify the acrylic to clear the extra capacitors on the block. You would also need thicker thermal pads for 3 areas where the VRMs would not make contact w/ the 780 block.
If you are good with a dremel I say go for the 780 block if it is significantly cheaper.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old April 24, 2014, 07:59 AM
Just send their support a message. They usually respond quickly.
Old April 24, 2014, 09:03 AM
SAS SAS is offline
ok, thanks!
Old April 25, 2014, 07:27 AM
Dazmode's Avatar
will not fit.
Orange Build: Final Video
HTPC Build: Final Video
GTX 780ti or 290 with waterblock? magictorch Video Cards 29 December 5, 2013 04:11 AM
MSI GTX 580 Reference with XSPC waterblock Justin Cider Price Check 2 January 16, 2012 02:28 PM
Will this work with a MCP 355 w/XSPC top? matari Water Cooling 5 February 3, 2011 08:06 AM
[FS] Visiontek 4870X2 with XSPC FC Waterblock Apollo4g Buy/Sell & Trade 14 September 23, 2009 01:03 PM
