Old April 23, 2014, 03:11 PM
Default Very noisy D5
Hi, one of the reasons I picked a D5 as my pump was because I heard that it is quiet. My experience hasn't been similar. I have had my loop put together for a few months, and my pump has been the noisiest part of my PC by far. I've recently been trying to find a way to make it quieter but I can't seem to make any progress. My pump is audible from about 15 meters away. There isn't any air in my loop. Can I get a resistor to connect to the Molex cable to step it down from 12v to 7 or 9? Or are there any other ways to slow it down?
I'm a bit upset because of it. A lot of money spent to have a quiet computer, and well... it's anything but quiet lol .
I would appreciate any help that you could give.
Old April 23, 2014, 03:17 PM
SugarJ's Avatar
I'm assuming you didn't get the variable speed model? Yes, you can try running it off 7 volts, by changing the black and red wires around on the Molex connector you are attached to. See pinout here: Molex connector - Wikipedia, the free encyclopedia
Old April 23, 2014, 03:25 PM
Yes. unfortunately, I didn't get the vario model. I heard that switching the cables around like that can damage your power supply, Is this a reasonable thing to be afraid of? And does it matter which black wire I change with the red one?
Old April 23, 2014, 03:47 PM
lowfat's Avatar
If you can hear the pump from 45 feet something is seriously wrong. Even on a non Vario model. Is the pump decoupled? Are you using an aftermarket top? If so open it up and verify that nothing is hitting the impeller. It may be a good idea to see this anyway. Look at the ceramic bearing to see if it is damaged while you have it open.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old April 23, 2014, 03:51 PM
The pump is not decoupled but it is in a bay reservoir. I think this is part of the problem. Next time I refill my loop I will take the pump apart and take a look at it.
Old April 23, 2014, 04:56 PM
KaptCrunch's Avatar
first note when pulling rotor/impeller it's magnetized to pump body so when replacing rotor back on
have a very strong grip to rotor so that it don't be sucked out of your hand like lighting and slam on to the ceramic ball damaging it
other is the 0-ring may be too thin or torqued down extreme , use some Play-Doh Plus or non-sticking putty to place inside pump inlet face about 3/8" high blob assemble and re open an check thickness of putty
Old April 23, 2014, 05:15 PM
mines nearly silent and I have the d5 strong. If the air has been removed from the loop there may be something stuck in the impellor. Assuming you've bled all the air from the loop.
Mah Rig now
Mah Rig before
My stuff for sale.
Old April 23, 2014, 05:45 PM
sswilson's Avatar
I've found that the only way to keep my bay res loop properly free from air is to ensure the res is filled right to the very top and actually work the residual air bubble(s) from the res itself out even though you wouldn't think it's going through the loop.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old April 23, 2014, 06:07 PM
agreed sswilson
Mah Rig now
Mah Rig before
My stuff for sale.
Old April 23, 2014, 06:40 PM
I also think that people overestimate how much you have to torque an o ring seal to maintain water tightness. I have worked on 40,000 - 80,000 PSI pumps that are o ring sealed and you don't need to gorilla grip tighten them. Just a firm 1/4 to 1/2 turn from hand tight. Easy does it is the ticket.
Tags
d5 pump , laing , loud , noisy , pump
Is the stock Intel fan noisy? bliz Air Cooling 9 November 20, 2012 11:04 PM
Antec Earthwatts 500W Noisy geokilla Power Supplies 10 March 28, 2012 03:15 PM
ATI 3870HD fan is noisy what can I replace it with? Shadowmeph Video Cards 2 December 21, 2009 10:10 AM
Noisy Fan on PSU Kayen Power Supplies 6 August 29, 2009 11:58 AM
OCZ StealthXStream 600W = noisy PSU Jacka Power Supplies 1 December 14, 2008 05:57 PM
