  #21 (permalink)
Old April 25, 2014, 03:29 PM
KaptCrunch's Avatar
McDoorKnob
can you take a pic of rez pump cavity
seems rotor is rubbing cavity
  #22 (permalink)
Old May 3, 2014, 01:50 PM
I have always used a vario D5 and I do find it to be a bit noisy at 4-5 setting, but it should not be to the point where you can't stand it since you also have a bunch of fans running on your rads too
  #23 (permalink)
Old May 6, 2014, 03:40 PM
Ashihtaka's Avatar
How is it mounted? Is it touching the case? If so, try a dampener such as a sponge or something.
Tags
d5 pump , laing , loud , noisy , pump
Is the stock Intel fan noisy? bliz Air Cooling 9 November 20, 2012 11:04 PM
Antec Earthwatts 500W Noisy geokilla Power Supplies 10 March 28, 2012 03:15 PM
ATI 3870HD fan is noisy what can I replace it with? Shadowmeph Video Cards 2 December 21, 2009 10:10 AM
Noisy Fan on PSU Kayen Power Supplies 6 August 29, 2009 11:58 AM
OCZ StealthXStream 600W = noisy PSU Jacka Power Supplies 1 December 14, 2008 05:57 PM
