Old April 23, 2014, 08:05 PM
The hard-mount on a bay res with integrated pump will transmit vibration like crazy. For that reason alone I always plumb my loops in such a way I can decouple the pump with some very soft tubing and a nice sponge pad.
heatware
Old April 23, 2014, 09:21 PM
Originally Posted by turtletrax View Post
I also think that people overestimate how much you have to torque an o ring seal to maintain water tightness. I have worked on 40,000 - 80,000 PSI pumps that are o ring sealed and you don't need to gorilla grip tighten them. Just a firm 1/4 to 1/2 turn from hand tight. Easy does it is the ticket.
yup especially extremely low pressure like a d5
Mah Rig now
Mah Rig before
My stuff for sale.
Old April 24, 2014, 07:43 AM
I've had a D5 in a single bay res and I could hear it but not from 15m away. What case are you using, perhaps it is nasty resonance...
Old April 24, 2014, 07:57 AM
I'm using a Corsair C70 case, and the res is an XSPC dual bay res.
With the amount of noise that it's making it probably is a problem with the pump as others have said. I plan on taking it apart later today to check it out.
Old April 24, 2014, 12:19 PM
might be some trapped air in there man... I have the same res and no noise.
Mah Rig now
Mah Rig before
My stuff for sale.
Old April 24, 2014, 01:43 PM
lowfat's Avatar
The XSPC reservoir is the issue. I have seen many complaints of the same issue. It is not decoupled at all and transfers all vibrations to the case.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old April 24, 2014, 03:57 PM
SugarJ's Avatar
I'll agree. I have one of those XSPC pump top/reservoirs and found it surprisingly noisy compared to how my pump was with a different top on it.
Old April 24, 2014, 10:20 PM
dustin1706's Avatar
I've always run D5 varios and even on 5 they should be barely audible from 1-2m in a closed case. I have two in my current case in a koolance bay mount on setting 3/5 and they are completely inaudible over my 700 RPM noctuas. I concur with the above. Sounds like you have a bad pump or that reservoir conducts vibrations really well.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
  #19 (permalink)
Old April 25, 2014, 05:58 AM
Well that's unfortunate. I really like the reservoir otherwise. I'll see what I can do to dampen the vibrations.
I also took apart my pump last night and here are the pictures of what I saw. https://imgur.com/a/gqZby
Everything seemed undamaged but I am not sure.
  #20 (permalink)
Old April 25, 2014, 07:32 AM
Dazmode's Avatar
I bet pump full of air.
edit: Also, yes bay reservoirs are noisy. That is trade of for convenience of having it in front.
Orange Build: Final Video
HTPC Build: Final Video
Tags
d5 pump , laing , loud , noisy , pump
Is the stock Intel fan noisy? bliz Air Cooling 9 November 20, 2012 11:04 PM
Antec Earthwatts 500W Noisy geokilla Power Supplies 10 March 28, 2012 03:15 PM
ATI 3870HD fan is noisy what can I replace it with? Shadowmeph Video Cards 2 December 21, 2009 10:10 AM
Noisy Fan on PSU Kayen Power Supplies 6 August 29, 2009 11:58 AM
OCZ StealthXStream 600W = noisy PSU Jacka Power Supplies 1 December 14, 2008 05:57 PM
