  #41 (permalink)
Old March 26, 2014, 11:40 AM
did some freehand bending and these tubes are super easy to bend, ill have to order more eventually. highly recommend.
ill start putting it into the system soon.
no scratches or imperfections of any type.
  #42 (permalink)
Old March 28, 2014, 10:02 AM
After spending about a week trying to find a source for the PETG tubing (that would ship to Canada) I ended up ordering 48' (it comes in 6' lengths) from Excel Plastics. McMaster didn't want to send (I suspect) such a small order to me in Canada and have to deal with the paperwork. And then, even when I set up a US address for them, they still did not want to send it to me as it would be exported to Canada and for some reason they had concerns.
Oh well - I am hoping the stuff I get from Excel is exactly the same and look forward to playing around with it. I need to move some stuff in my Red Rampage Round II build (I need to move the pumps and also add in two more rads) so if this tubing works as well as that one video it should be pretty easy.
Also curious that another one of my acrylic tubes cracked - don't think it is an issue with the Primochill acrylic just something that I must've messed uo?
  #43 (permalink)
Old March 28, 2014, 03:34 PM
you mind posting a link to Excel Plastics? it would be very good to have an alternative up here in Canada. also please post an update after you get their product and share your experience.
i am not sure about your tubes maybe you can post a photo or a more detailed description, but frankly im not surprised. acrylic is VERY brittle, thats part of the reason i decided to jump on the hard tube wagon this late. i wanted an alternative that was better then acrylic. and hopefully this petg tube is it.
  #44 (permalink)
Old March 29, 2014, 05:33 PM
Radish,
Here is the link to Excel Plastics: Petg Tubing by Excel Plastics
Note that they would not ship to Canada either so I am using one of those US address services at the border - they apparently have no problem shipping there. As for my tubes, and the cracking, you can check out my hardware log in the build section - it's called Red Rampage II. What's interesting is that the cracks started to happen after (my speculation) my system started heating up (when I stress test it). When I am not running anything heavy, my rad out temperature is around 27c and nothing was leaking.
However, once I fired up BF4 for the first time, the coolant temperature on the output of the rad went up to 42c (couldn't get a rad in temperature - something wrong with the sensor). Anyway I am speculating that the extra heat (and pressure) were the causes of the cracks, and that's when it starts leaking. It's interesting - I can see a crack that has grown on the tube run connecting the two m/b blocks - and as long as the coolant stays under 30c, it won't leak. I can play Civ5 for about 15 minutes which is enough to start raising the temp up, and then the crack starts leaking again.
Anyway, PETG tubing should show up next week and I will post some updated info on the experience. Also note that Daz is in the loop here (no pun intended) and he said he might start carrying the tubing. Guess we can wait and see.
B
  #45 (permalink)
Old March 29, 2014, 06:23 PM
Originally Posted by bjcsoln View Post
Radish,
B
Do you ever go on overclock.net? there is a massive thread there about acrylic pipe...
My thinking is that you may not be heating the acrylic enough for your bends leading to it cracking...
My 2 cents is stick to Acrylic as most plastics stores carry the sizes needed for all the standard fittings sizes, I just bought 18ft of it for 15 bucks at my local plastics store... I know a few guys on OCN did some testing and found that the PETG tube turns yellow from uv lighting.... (sunshine etc...) just something to keep in mind if the case gets any sunlight what so ever.....
  #46 (permalink)
Old March 29, 2014, 06:29 PM
lowfat's Avatar
I am still not convinced PETG is the way to go for long term tubing. It is not protected against UV. I bet it will yellow over time.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #47 (permalink)
Old March 29, 2014, 07:08 PM
QFE
Nice to see a fellow Albertan and OCN member here
  #48 (permalink)
Old March 29, 2014, 11:00 PM
Radish,
B
Hey 1stly thanks for the link. 2nd I think as mentioned there are two factors I would consider.first is you may have cooled the acrylic too rapidly, or not heated it enough, causing the plastic to be extra brittle. Also I would check for vibration. When you stress the system the I'd assume the entire thing has a huge increase micro vibrations the may cause cracks if the plastic is brittle. But that's just an educated guess... I maybe wrong.
Also I was thinking because the tubing isn't UV treated, yellowing might be an issue but hopefully I'll replace my parts before that. Im not running any lighting in the rig its not in direct sunlight and there's no window. So I hope that will prolong the clarity of the tubing. But if it does go yellow I can always sleeve it or paint it.
  #49 (permalink)
Old March 30, 2014, 11:25 AM
I can tell you from experience that painting plastic is pretty horrible. My suggestion would be to sand all the tubing really well before using any kind of paint and I would suggest plastidip.
Mah Rig now
Mah Rig before
My stuff for sale.
  #50 (permalink)
Old March 30, 2014, 02:11 PM
Radish,
Can you clarify a bit more on how the higher stress may increase micro-vibrations? I am curious about that - right nothing changes in my loop as the temp goes up (i.e. the fans always stay at 100%, and I have also left the pump power static) so I am not sure where they would come from? Or is it just one of the byproducts of the increased amount of power output (some being lost in the form of heat, some being lost in the form of micro-vibrations?).
I do know that I let all of the bends air cool (so I don't think that would be a source for the increased brittleness) but your comment about not enough heat might be on the mark. Watching the Primochill video, they show slowly testing the flexibility as the tube heats up, perhaps trying to force it / stress it before it is fully heated could leave a lasting artifact that could turn into a crack. I wonder if Primochill would have anything to say on this?
[FS] Macbook Air 13" hard/soft shell cases and keyboard protector writhen Buy/Sell & Trade 15 March 16, 2012 08:46 PM
Why Dell is going down the tubes Sagath Off Topic 26 July 21, 2010 10:36 AM
Thoughts on "noob tubes" in BFBC2 mike.mgs4 Gaming 164 March 26, 2010 09:29 AM
[WTB] antec 900,260 Waterblock,UV tubes, H50 ottoyu34 Buy/Sell & Trade 10 November 22, 2009 06:36 PM
film in tubes kyle_L Water Cooling 10 January 7, 2009 04:25 PM
