Old March 7, 2014, 02:33 AM
Bungwirez's Avatar
To bend the acrylic, You really don't need any special tools other than a good heatgun, that flexi tube insert to prevent collapse and some soapy water.
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old March 7, 2014, 04:38 AM
ZZLEE's Avatar
https://www.youtube.com/watch?v=0pcKy7arIFg
MNpctech vid
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old March 7, 2014, 08:14 AM
10e's Avatar
10e 10e is offline
I'd also suggest a decent fretsaw or hacksaw to cut the tubing and some 320 grit sand paper to "chamfer" or taper the edges. The fittings use either a single fat o-ring (Primochill) or two smaller o-rings to seal around the tube. Rough edges can cause a worse seal, and when you cut the tube it can leave a sharp edge which can damage the o-rings. Otherwise the above suggestions are 100% bang-on.
Another approach to cut the tubing is a Dremel or rotary tool with one of their cutting wheels. I use this one to cut acrylic and it works better than any of the dark grey cutting wheels I've used:
543 Cutting/Shaping Wheel / Model: 543
The reason this wheel is best is because it doesn't melt the acrylic like the other Dremel wheels do.
I plan on doing my first two WC builds with hard tubes over the next few weeks.
Old March 7, 2014, 10:08 AM
Another huge benefit in my eyes is getting rid of all the plasticizer that eventually gum up the works when moving from soft tubing to hard tube. Assuming you use quality coolant and a properly cleaned loop, you essentially never need to clean your loop again. That along with the overall look and great flow are why I plan on doing my main rig. After I get that figured I will be moving my other rig to hard tube too.
Old March 7, 2014, 11:16 AM
Bungwirez's Avatar
Originally Posted by 10e View Post
I'd also suggest a decent fretsaw or hacksaw to cut the tubing and some 320 grit sand paper to "chamfer" or taper the edges...
derp... good point 10e.
I much prefer The Rimmer:
Old March 7, 2014, 04:48 PM
lowfat's Avatar
Using acrylic and not having the loop look like crap can be a lot of work. So if you don't have a ton of patience I would avoid it. But like turtletrax said not having placticizers in the loop is a huge plus.
The Monsoon bending kit can really help out. It comes w/ a ton of stuff that will assist w/ bending, measuring, and cutting the acrylic.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 7, 2014, 07:14 PM
Looks like you got the hang of the monsoon kit after awhile by the looks of your Lian-Li project. How much tube did it taker before you felt comfortable? I have 10 meters and I was hoping to get at least 3 rigs out of it.
Old March 7, 2014, 07:38 PM
lowfat's Avatar
I used 20 feet on my Lian Li and I am not happy w/ the any of the bends. Unfortunately ran out of tubing so I couldn't redo them. I haven't found a place to buy 3/8" ID 1/2" OD tubing in Canada yet.
Queen of Dreams WIP
Big Lian Li
Complete
  #19 (permalink)
Old March 7, 2014, 10:40 PM
Ouch. Looks like I might not even get two out of my 33ft. I would sell you some if it wasn't 10/12mm.
I still have to buy blocks for my titans before I begin tubing my rig up. Debating some other purchases before I put in my order.
  #20 (permalink)
Old March 8, 2014, 04:36 AM
Bungwirez's Avatar
Hey man, when you do would you mind sharing? I've been on the look out for a little while, and definitely don't want to have to go with McMaster-Carr...
[FS] Macbook Air 13" hard/soft shell cases and keyboard protector writhen Buy/Sell & Trade 15 March 16, 2012 08:46 PM
Why Dell is going down the tubes Sagath Off Topic 26 July 21, 2010 10:36 AM
Thoughts on "noob tubes" in BFBC2 mike.mgs4 Gaming 164 March 26, 2010 09:29 AM
[WTB] antec 900,260 Waterblock,UV tubes, H50 ottoyu34 Buy/Sell & Trade 10 November 22, 2009 06:36 PM
film in tubes kyle_L Water Cooling 10 January 7, 2009 04:25 PM
