Old March 3, 2014, 06:58 PM
Default Question on res size...
Hey I am doing a mITX build in the next month or so... just trying to source all the final parts...
Just have a question on res size.... I am eyeing the EK 110mm tube res for my build and am using a single 240mm radiator with a 30fpi and using an EK supremacy block and a EK titan/780 block....
Will having a larger or smaller res effect my temps? yes I do know some of you will say I don't have enough radiators etc.. I have seen this build done and it works highest temp the guy sees is 75ish... and that's in south Floridia on a hot day.....
thanks....
Old March 3, 2014, 07:22 PM
resi size makes very little difference man... if its smaller it needs a little more attention during the filling process. Bigger resi's need less attention. Considering the size of rad/resi and heat you are pulling I would definitely consider installing a thermal expansion fitting.
https://www.dazmode.com/store/product/pressure_valve/
It needs an air gap to work right though... generally the highest part of the loop or a low pressure area like a resi.
Mah Rig now
Mah Rig before
My stuff for sale.
Old March 3, 2014, 07:31 PM
lowfat's Avatar
Bigger reservoirs are easier and quicker to bleed but that is about the only benefit.
May I add 30 FPI radiators are generally a bad idea. They tend to require fans north of 2000 rpm to perform decent. If you are trying to save space go w/ an XSPC AX or Swiftech MCR series rad instead of the Black Ice Stealth or Koolance rads.
Old March 4, 2014, 02:32 AM
KaptCrunch's Avatar
Liquid Coolants
Koolance's product warranty does not cover the use of 3rd-party coolants, coolant additives, or corrosion. Koolance LIQ-702 or LIQ-705 coolants are strongly recommended to help avoid issues with mixed metals or biological growth. Additionally, do not use aluminum with bare (unplated) copper or bare (unplated) brass in the same system. Do not use silver with nickel in the same system.
no check valve here its just a breather with felt
Materials of VLV-VL002K Wetted Materials Nickel-Plated Brass, EPDM
use their coolant or growth
now if installed on bottom of rez , would have yourself a puddle
best have rad outside the case so not to recycle heat for best cooling an still use case fans for inside
only rez size matter if using a RD-30 pump
Old March 4, 2014, 06:13 AM
ZZLEE's Avatar
http://products.ncix.com/detail/swif...72245-1294.htm
Works fore me in my Prodigy :)
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old March 4, 2014, 06:21 AM
sswilson's Avatar
Originally Posted by ZZLEE View Post
Ye ol' standby..... probably aren't too many older WC'ers who haven't had one of those in at least one build.... ;)
Not pretty, but certainly functional.
EVGA X58 3X SLI / i7 980X / 3X 4G Mushkin Blackline Frostbite / XFX Pro 1000W / EVGA GTX 680 SC+ 2GB / Intel DC S3700 200G / WD 6401AALS / TT Lvl 10 GT
Gigabyte C1007UN-D / 2X4G Gskill PC3-10700 / Pico PSU / 2.5" 750G Toshiba HDD / Mini-Box M350 / 1X 19" BenQ / 1X 17" HP
Old March 4, 2014, 07:10 AM
Thanks guys, I am looking for an Alphacool NexXxos ST30 since it has a lower FPI but cant seem to find one under 50 bucks before shipping :(
Once i get all my stuff I will post a build log under case mods...
6970 size question NyteOwl Video Cards 2 November 20, 2011 02:51 PM
Help with fan size biagio1661 Air Cooling 5 October 25, 2011 02:07 PM
Tubing size Chipset Question elwoodz Water Cooling 5 December 14, 2009 03:04 PM
Sleeve size question donkon Guides & How-to's 0 June 27, 2009 11:53 AM
video card size question esanity Cases 3 February 16, 2009 11:06 PM
