Old February 21, 2014, 07:36 AM
Keyz's Avatar
Question Red Sleeved Tubing vs Clear Tubing with Red Dye
Hi, just experimenting with different options. Which look do you prefer? (Sorry about pic quality, still WIP)
Old February 21, 2014, 08:35 AM
Caldezar's Avatar
You're likely going to get an even split as it's such a subjective question.
Personally, I like the sleeving much more. I've always disliked the look of water loops with transparent tubing. I can't really say why, but maybe it has something to do with the liquid never being a rich enough colour for my taste? Regardless, the sleeving gives it a nice, clean, 'finished' look IMO.
Old February 21, 2014, 09:01 AM
Bungwirez's Avatar
Sleeve.
then you can stick to basic Distilled and DazProtect :P
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old February 21, 2014, 09:15 AM
+1. I never find the colour rich enough. I don't mind coloured tubing though. The sleeving is nice. I'm just not used to seeing it enough, that and I like the look of textureless tubing.
Old February 21, 2014, 12:19 PM
lowfat's Avatar
I am a fan of the sleeved tubing obviously.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old February 21, 2014, 01:14 PM
Bond007's Avatar
I would say sleeving as well, but that pic makes it look more orange then red. It really it depends on what look your going for. If you have lights in your case the clear may look better by allowing light through, but I wouldn't really light a case up much, so I would prefer the sleeve.
Old February 22, 2014, 09:48 PM
put the sleeve in a tube, or use a solid color non textured tube, the dye will change the color of the tubing eventually which I have seen and it makes it look yuck, not to mention it could and has messed up many a block as it is a suspended product in the liquid so it can and will eventually separate/stick and so forth, I do like the dye look however, maybe there is some LED lighting or whatever you could use to get that really rich color but also have the best liquid in use without worrying about changing of color or whatever.
Old February 22, 2014, 09:59 PM
Birk's Avatar
I'd choose Sleeved.
Old February 23, 2014, 08:43 AM
Keyz's Avatar
Thanks for the feedback guys. To be honest I was surprised to see so much support for sleeved tubing, considering I've barely seen any builds using it (the only I can remember is lowfats blue sleeve - that's what what gave me an idea to sleeve, thanks ;)). The main reason I currently switched to clear + dye is that those Monsoon fittings are tricky to use with sleeving, you have to get the length just right (the sleeve has to end a few mm off the edge of the fitting), and the ends tend to start fraying after a few times the fittings are taken off / put back on.
Regarding the dye, from the research I've done it seems that separation really occurs if dye and other additives people use are chemically reactive, and dye "gunking up" the blocks is really just colored leached plasticizer, so I'm hoping for the best. I use distilled with Daz Protector and Feser dye, which are supposed to be compatible.
Old February 24, 2014, 12:53 PM
Keyz's Avatar
Tried editing the original post, however it got deleted for some reason. So here are the photos again.
Any clear tubing that doesn't cloud? geoc Water Cooling 8 June 14, 2012 12:47 PM
Primochill Tubing or any good tubing with thick walls in Vancouver Lower Mainland? bjornbjorn Water Cooling 5 January 26, 2012 05:19 PM
[WTB] 7/16 ID 5/8 OD Tubing enaberif Buy/Sell & Trade 5 September 27, 2009 07:32 AM
Where to buy WC tubing? sinn98 Water Cooling 8 August 24, 2009 06:55 AM
Tubing, tubing... what to choose? Dazmode Water Cooling 16 June 23, 2009 02:32 PM
