Just to make sure from your posts, these are the two options you're considering, right?
Parallel Tri-Fire
Series Tri-Fire
The parallel setup works in with two cards, but I don't know for certain if the middle card gets an equal share in a triple setup. Theoretically, it should, since you're using identical blocks.
An MCP-655 (at the high setting) will push through either loop without too much trouble, and the water shouldn't pick up more than a degree or two through each block.
If you want, it'll probably push through most CPU blocks as well, while still keeping flow above the 1.0gpm mark, but you'll want to make sure the CPU is the first block in the loop. And your radiator is definitely going to start to choke a little unless you're giving it some good, strong fans. An extra single rad wouldn't definitely be a good idea in that case.
